LSJ or LNF Themostat Hosing ?
Old Sep 25, 2012 | 06:13 PM
YelCal7's Avatar
Hey Guys, I was checking around LSJ and LNF Themostat Hosing. I wanted to know which one flows better ? And have anyone done the swap ?
Old Sep 25, 2012 | 10:38 PM
Tjolley's Avatar
just wondered...y would u change it...the stock lsj one works fine
Old Sep 25, 2012 | 10:43 PM
noorj's Avatar
I'm almost positive they "flow" the exact same. The only difference/reason to change is for the degree is goes full open at, which I believe is the LSJ thermostat (170* IIRC)
Old Sep 25, 2012 | 11:02 PM
Tjolley's Avatar
the thermostat that comes in the lsj stock works very well for most performance needs...
Old Sep 25, 2012 | 11:11 PM
nhanson's Avatar
I believe they are different?
Old Sep 26, 2012 | 12:18 AM
YelCal7's Avatar
What I was looking at LSJ and LNF Themostat Hosing is alittle bit different. Look at the Hosing that go to Themostat and there are 2 different route to it between LSJ and LNF.
Old Sep 26, 2012 | 12:33 AM
Tjolley's Avatar
not to be a ***** but i would stick with the lsj on a lsj....it works well i have never hurd of a issue with it..gm used it on every build if Im not mistaken..
Old Sep 26, 2012 | 10:43 AM
YelCal7's Avatar
Ok
Old Sep 27, 2012 | 05:11 PM
Ryan@zzp's Avatar
You have to swap the entire housing for a few reasons.
1. The bolt pattern is different on the water neck
2. The oil cooler setups are different
3. sensor location
4. The heater core connectors are totally different.
I don't know why you would even consider swapping. Seems like a weird thing to think about, but I guess.
Old Sep 27, 2012 | 11:20 PM
noorj's Avatar
Does anyone know if LE5 to LSJ would make a difference? I'm almost positive they are different thermostats
Old Sep 28, 2012 | 08:37 AM
Ryan@zzp's Avatar
It would if you were deleting your oil cooler, but thats about the only advantage. Your biggest gain would come from removing the T-stat. Only in the LSJ.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
