LSJ Modification Guide
Old Oct 27, 2010 | 03:40 PM
  #51
b00sted06ss's Avatar
great list of parts and options!
Old Nov 17, 2010 | 08:58 AM
  #52
recklessactn's Avatar
check yourself before you wreck yourself... read the guide newbs bump
Old Dec 3, 2010 | 01:56 PM
  #53
your monthly bumpage brought to you by LSJ sanity
Old Jan 9, 2011 | 04:07 PM
  #54
jgreene151's Avatar
Does anyone know of a tuning system for the 06 cobalt ss?
Old Jan 9, 2011 | 04:12 PM
  #55
CanadianCobalt's Avatar
Trifecta, HPT, BYT Tuning etc.
Joel
Old Jan 9, 2011 | 04:47 PM
  #56
jgreene151's Avatar
K thanks all check them out
Old Feb 17, 2011 | 05:25 PM
  #57
insylem's Avatar
Originally Posted by recklessactn
bc you dont gain any hp past 2.9 and 2.8 bring ups the wtq and any lower than that ur just creating alot of heat
How can you bring up torque without bringing up horsepower, RPM staying the same?
Old Mar 13, 2011 | 10:51 AM
  #58
bumpppage
Old Apr 29, 2011 | 11:38 AM
  #59
RooTBeeR's Avatar
bumpppage
you forgot an april bump
Old May 18, 2011 | 08:41 AM
  #60
welcome to the summer almost... newbs *bump for the infos*
lil busy but u got my back
Last edited by recklessactn; May 18, 2011 at 08:41 AM. Reason: Automerged Doublepost
Old Aug 1, 2011 | 11:45 PM
  #61
Boosted05's Avatar
Great write up, I'm on option 3 right now. But I'm a little of this and that ATM. Great write up!
Old Sep 16, 2011 | 11:48 AM
  #62
Jmc007's Avatar
Very good summary write-up, thank you. I would also like to add a comment about the supercharger pulley size limitations vs altitude. You can typically go 0.1 inch diameter smaller than suggested in post # 1 for each 1000 feet of altitude because of the lower density of air. This without the need for larger fuel injectors. The only thing to remember about is if you plan to run a smaller pulley because your hometown location is of a higher altitude, be prudent if you do a trip to a much lower altitude or if you move permanently to a lower altitude city, in this case you will need a bigger pulley unless you are willing to upgrade to bigger fuel injectors (and other supporting mods) as necessary.
Old Sep 16, 2011 | 12:00 PM
  #63
Jmc007's Avatar
If you plan to go turbo as route #4 recommends, here is a good write-up:
https://www.cobaltss.net/forums/2-0l...redline-70507/
Old Dec 21, 2011 | 09:26 AM
  #64
Learylax3r's Avatar
Looking at Route 3, is the ZZP stage 3 kit a good substitute for the 60 lb injectors, 2.8 pulley, and heat exchanger? It comes with 50# injectors, options for pulley size, probably gonna run the 2.8, and a zzp heat exchanger.
Old Dec 21, 2011 | 09:38 AM
  #65
Staged07SS's Avatar
Administrator
Administrator
Yep.
It will be a good start.
Old Dec 21, 2011 | 01:58 PM
  #66
insylem's Avatar
Nio..
HP is a multiple of torque and RPM.
... and now i'm talking to myself
Old Dec 21, 2011 | 03:08 PM
  #67
RooTBeeR's Avatar
^you sir are crazy
Old Dec 21, 2011 | 03:43 PM
  #68
Well this upcoming summer im going to start adding some performance mods to my car, im going the 2.6" route. I'll need alot of supporting mods for that correct? Like bigger h/e, option b, etc...
Old Jun 3, 2012 | 02:37 PM
  #69
Drunkship's Avatar
So I finally got all the little quirks sorted out in my car. I would like to start upgrading performance in my 06 SS/SC. First off I am going to get the FE5 strut/shock/Pedders springs kit.
After that, I want to get a cat-back exhaust. MA is really picky about failing inspections for exhausts being "too loud". I failed last year for my Accord's Thermal R&D cat-back being too loud even though it wasn't that bad. Because of this I want to get the GMPP cat-back installed so I can tell the inspection shop to kick rocks if they give me any problems. Is it a 2.5" or 3" system? Eventually I would like to get a ZZP downpipe and headers to go with it.
After that I want to get another CAI. If you guys remember me, the Injen intake that came with the car kept giving me CELs, so I brought it back to stock. I want to get the ZZP intake installed. However, I might just get it installed when I get a GM or ZZP Stage Kit so I can avoid any CEL with the ECU reflash.
So does GMPP cat-back --> ZZP downpipe/headers --> ZZP intake/GMPP or ZZP stage kit sound like a good upgrade path?
EDIT:
Just did a little more research and see that the GMPP exhaust is 2.25". Will the ZZP 2.5" downpipe not bolt up to it?
Old Jun 4, 2012 | 12:05 PM
  #70
insylem's Avatar
^you sir are crazy
I Guess I am, since afterall I did awnser myself
Old Jun 25, 2012 | 12:52 AM
  #71
danmanuele's Avatar
I'm just kinda getting into modding my car and feel so lost..I have 42 lb injectors stage two super headers exhaust 3"from cat back torque damper and a tune...now I just ordered from Zzp 60lb injectors ls4 throttle body.should that make any difference in HP? Also Zzp offers a pcm for that set up would that basically be a plug and play?
Old Jun 25, 2012 | 01:06 PM
  #72
insylem's Avatar
It should be. The tune that is. *IF* you send them your PCM FIRST. That way they can tune it and return you the same PCM. Otherwise you have to do a relearn. Also if you have HPT and they email you the tune, it's plug and play.
When I got my PCM back from ZZP I was on the road withen 45 minutes. That's counting the time to open the box.
Also consider some cooling mods and maybe a < 3.3" Pulley
Old Jun 25, 2012 | 05:05 PM
  #73
Learylax3r's Avatar
what exactly does a re-learn entail?
Old Mar 8, 2013 | 09:02 AM
  #74
1fastSSBalt's Avatar
So I am just a little curious. What kind of cooling is required for a 2.7 pulley, Euthenasia port n polished head, zzp lth/catted dp/2.5 ZZP catback, zzp cai 1000cc injectors. I have a GM dual pass and the zzp stg3 h/e. Would that little bit suffice ill also be on e85. Thought about grabbing the phenolic spacer or the new stealth h/e
Old Mar 8, 2013 | 09:06 AM
  #75
574's Avatar
574
You don't need those injectors with that set up
