LSJ-T Swapped Cav Build
Old Nov 9, 2015 | 05:54 PM
rousseaus99's Avatar
URL=http://s113.photobucket.com/user/rousseau9099/media/Mobile%20Uploads/20151109_164824.jpg.html]Name:  20151109_164824.jpg
Anyone have any ideas on what to do about this?
Old Nov 9, 2015 | 07:36 PM
Sharkey's Avatar
is it just hitting the stud or is it actually hitting the cam sensor housing? if its just the stud, swap it out for a normal bolt.
its kinda hard to tell from that pic
Old Nov 9, 2015 | 07:44 PM
Its hitting the sensor by alot
Old Nov 9, 2015 | 10:36 PM
Sharkey's Avatar
you have a few options. could rotate the engine forward in the car. could have a wedge spacer to go between the booster and firewall so it angles the master and booster up. could go with manual brakes. heck, you could put a tilton or wilwood pedal box with individual master cylinders in it.
Old Jan 2, 2016 | 06:48 PM
Just a quick update
Progress is slowly moving forward on the car. I have the exhaust built the tank is back in the car ECU is mounted but still have to make sure that its position does not interfere with the charge pipes. Radiator is back in the car and all plumbed in. Waiting on a few new couplings to come in the mail also am looking to order a brake booster for an aveo and I think that should clear the Cam shaft position sensor. Interior wiring is 90% done have to finish a few small things and I'll be back to modify the dash and putting interior back together. Engine bay wiring is almost done will dress things up after successful start up.
Old Jan 2, 2016 | 07:14 PM
Excitied to see her run!
Old Jan 25, 2016 | 09:31 PM
Update. New clutch is in and charge pipes are painted. They look satin black till the light hits them. Its a custom color i mixed at work. Also some pics of the aveo booster setup. Next i plan to get the front end back together so the car can be set back down then figure out what is going on with the p0230 and no fuel and spark issue im having.
*Name:  20160112_132410.jpg
*Name:  20160123_142634.jpg
*Name:  20160123_142647.jpg
Old Jan 25, 2016 | 09:37 PM
And i forgot i havent even posted a pic of the cavi yet. Here it was a few years ago before the motor went. Dont have those rims anymore and i have a 1.5" drop springs for it too. I am also doing some customized ss side skirts for it and a custom front and rear lip. But those are at the end of the project list. Need to get it back on the road first
Old Feb 14, 2016 | 02:13 PM
Car starts and runs, I have an exhaust leak somewhere so I ordered some new gaskets also have a coolant leak somewhere below the pipes that go to the heater not sure quite what it is yet. Next step is to get the dash done and interior back together while i wait for some parts to show up.
Old Feb 14, 2016 | 02:24 PM
Awwww yee
Old Feb 14, 2016 | 03:28 PM
  #36
Squints's Avatar
Originally Posted by rousseaus99
Finally have had a chance to get some work done on the car. I have been so busy lately with customer cars and life in general. Progress on the car will be slowing down a littlw just watching my cash flow with just having purchased my wife a new car. (2015 ford fusion ecoboost) which will be modded when the warrenty is up. But in the meantime here is a shot of the progress in the past couple days. My only thing im not sure of is what to do in place of the vents. There is no heating or cooling in the car anyone have some good ideas?
Yes its twisted a little moved when bonding but will correct it when im done.
Honestly you could modify the center vents to be a housing for gauges
Old Feb 14, 2016 | 06:39 PM
  #37
Haven07's Avatar
I think the Guages would be a good idea as well
Old Feb 14, 2016 | 06:42 PM
  #38
I will need more gauges i have aem truboost and innovate wide band need a fuel pressure for sure
Old Feb 14, 2016 | 06:53 PM
  #39
Sharkey's Avatar
the 2 gauges id put in- wideband and aeroforce interceptor. the interceptor will tell you boost, and thats something you dont need to monitor all the time anyways. add a fuel pressure sensor to the analog input and there ya go. plus itll monitor the things you really need to watch, like knock retard and iat2 temp.
Old Feb 14, 2016 | 07:01 PM
  #40
I like the aeroforce but already have the truboost which i use as a boost controller also
Old Feb 14, 2016 | 08:31 PM
  #41
Haven07's Avatar
What about exhaust temp sensor? Pretty helpful on a turbo car. Also if you planned to track a lot if grab a oil temp sensor
Old Feb 15, 2016 | 07:18 AM
  #42
Squints's Avatar
You can always put an aeroforce in to monitor your IATs
Old Feb 19, 2016 | 06:43 PM
  #43
Can anyone help me to connect the cavalier ignition switch to the cobalt wiring? Its one of the things left of the few things to do to complete my swap.
Old Mar 6, 2016 | 07:27 PM
  #44
Ok car is running and kind of driving. Need to get some different injectors but that will have to wait till funds become available. Couple of questions tho. Are all engine bay fuse / relay boxes the same or are the ss' different. Also can anyone help me with a base tune to make the car more drivable just starting to learn how to tune
Old Mar 6, 2016 | 07:50 PM
  #45
Which fuse box did you use? What year ecu and fuse box?
Old Mar 6, 2016 | 07:52 PM
  #46
The one in the engine bay with the fuel pump relay. Its all 2006
Old Mar 6, 2016 | 08:26 PM
  #47
The ss and base did use different boxes if thats what youre asking
Old Mar 6, 2016 | 08:35 PM
  #48
Yes thats what i was wondering. Thanks. Now can anyone help me get started with a tune
Old Mar 6, 2016 | 08:49 PM
  #49
What do you need to know?
Old Mar 6, 2016 | 08:52 PM
  #50
Everything lol. Where to start would be good stock except balance shaft delete and turbo swapped. MAF has been relocated ao im sure i have to tune forw that. Return fuel set up
