LSJ-T Swapped Cav Build
Old Mar 6, 2016 | 08:55 PM
  #51
rousseaus99's Avatar
I have been on the hpt forums reading up but would like a little more guidence getting a good base tune set up
Old Mar 6, 2016 | 09:14 PM
  #52
Ask away
Old Mar 6, 2016 | 09:20 PM
  #53
So start with closed loop tuning? Make a few runs smoothly through the rpm range use that data to adjust fueling to hit target afrs basically? What are the major things i need to change when going from supercharger to turbo or is it just adjust fuel maps. When moving the maf location im assuming there is something special to tune for that
Old Mar 6, 2016 | 09:25 PM
  #54
What most people do is disable the VE by setting the dynamic airflow enable/disable really low. This gives your maf table full control of the fueling for the most part. Pretty much you just set up a histogram in the scanner which should already have a set up for your maf table. Then you create a user defined pid that adds stft+ltft. This gives you your maf error. Make sure youre logging maf frequency, stft, and ltft in the table display. Pretty much just cruise around for 20 minutes once the car is fully warm and you should have a good cell hit count which can be checked in the histo. Look for threads on closed loop maf tuning for more detail on this.
Old Mar 8, 2016 | 06:29 PM
  #55
Just ordered 80lbs injectors and will be ordering a couple new gauges when extra funds are available. Here are a couple pics ss back seats are in and will be doing the fronts soon.* Also this winter i will clean up the wiring and the engine bay and start the custom bumpers and hood
*Name:  20160308_165449.jpg
*Name:  20160308_165612.jpg
Old Mar 8, 2016 | 09:05 PM
  #56
Damn. are the back seats pretty much the same?
Old Mar 8, 2016 | 09:08 PM
  #57
Little different most people have modified the cavalier bracket to mount them. I just bolted in the cobalt one instead. The bottom doesnt clip in they are a little wider and shorter
Old Mar 10, 2016 | 08:10 PM
  #58
I have 80lbs injectors in now and want to make sure I am setting everything correctly for a return fuel set up. can anyone chime in on this
modifier is set to 1.6
FR vs KPA VAC is 63
Stock rail pressure is 58 and new rail pressure is 43
58-43=15 = 103 KPA
Use the -101 KPA and set all of them to that
Old Mar 10, 2016 | 09:18 PM
  #59
Haven07's Avatar
This thing is coming along nicely, can't wait to see it braking hearts
Old Mar 10, 2016 | 11:57 PM
  #60
FR vs KPA VAC is 63
58-43=15 = 103 KPA
You need to scale the ecu or turn down the base pressure enough to fit into the limits of the IFR table. I learned from armcclure that the volts modifier will only take you to the 63 lb/hr limit.
Old Mar 11, 2016 | 10:58 AM
  #61
GBRunner24's Avatar
Wow! Good work man, keep it up. In for progress.
Old Mar 12, 2016 | 10:30 AM
  #62
What would be your suggestion for setting the base pressure?
Old Mar 12, 2016 | 12:10 PM
  #63
Theres a member on here named RedLined. I would talk to him about scaling your tune.
Old Mar 12, 2016 | 12:11 PM
  #64
http://injectordynamics.com/wp-conte...SteckScale.pdf
Old Mar 12, 2016 | 01:03 PM
  #65
Haven07's Avatar
You talking about injector scaling? If so there is a guide (at least to do 60's ) on the ho tuber forums
Old Mar 12, 2016 | 01:40 PM
  #66
Im talking about scaling everything that references airflow so you can enter half of your actual IFR. Hpt forums are good for some things but i wouldnt trust most of the injector how tos.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
