LSJ Turbo Issue...
LSJ Turbo Issue...
Ok I'm going to keep this as short as possible.
I started the car after work, it idled for about 2 minutes, and started to idle very rough, and died. Hasn't started since. It will turn over and start, idles for about 2 seconds, and all of a sudden starts to idle like **** again and dies.
-Has fuel
-Has spark
-Is getting air.
No check engine light at first, finally threw a code, P0033, which is the supercharger/turbo bypass. that is eliminated because i'm turbo. Any ideas where to start?
-Has fuel
-Has spark
-Is getting air.
yup, 180s across the board, i've checked for vaccuum leaks, make sure it didn't have a bad ground, battery is fine, alternator is fine...idk lol I thought maybe the timing chain jumped at first, so I pulled the timing cover and everything checked out there too.
