m62 to m90..how about it INTENSE ??
Old Jul 7, 2006 | 04:28 PM
veloom's Avatar
2006ArrivalBlueSS: Excellent right up.
I think there is a lot of misinformation out there around superchargers and size.
Old Jul 7, 2006 | 04:32 PM
2006ArrivalBlueSS's Avatar
Thanks, but I can't take credit for the write up - just a good find is all I guess
Old Jul 7, 2006 | 04:35 PM
SchwarzCamaroRS's Avatar
Originally Posted by BooSSted
Twincharging has already need done on a Redline and an SS. "Twincharged" on the redline forums did his and Keith Losier has twin charged his Cobalt (Show Car). Keith has the Hahn Racecraft kit on his.
how much power are they making?
Old Jul 7, 2006 | 04:44 PM
cavingman's Avatar
Originally Posted by Blown 4-banger
Don't worry about it, Fast06SS runs 12s and puts down like 280 whp and hasn't had any tranny issues other than blown axles but thats not the tranny itself. Plus on the redline forums theres alot of guys with 280+ whp and no blown trannys (that I've heard of)
dig a little harder...
there are quite a few of us on tranny #2
mine let go at a certain track in my area. had to push the car out to the road then call roadside :\
when i met him, twincharged made 330whp that afternoon. this was about 3 weeks ago.
Old Jul 7, 2006 | 04:51 PM
Kahless's Avatar
gravana i think was supposed to be making a twin charged setup for sema this year. i think they said something about it last year being good for 300whp.
Old Jul 7, 2006 | 05:45 PM
selfinfliction's Avatar
I am already running 18 PSI and a couple people are running a bit more than that with the 2.5" pulley. How much more boost to you expect to be able to run on a stock motor without blowing it up?
i know the head gasket goes at 24psi (confirmed by blowing it a second time at the same boost levels)
you can break that with a blower swap... easily
Old Jul 7, 2006 | 05:59 PM
stuffy236's Avatar
i predict that the m90 kit will be as popular as the m112 kit for the grand prix that intense sells... hmmm how many people have that again??
Old Jul 7, 2006 | 09:12 PM
AlphaJaguar5's Avatar
Any hints of a screw type in the near future?
Old Jul 7, 2006 | 10:56 PM
vandy0419's Avatar
I love the idea of a different supercharger on the car...whether it is M90 or what not, but if the price of doing a M90 is going to cost as much as when they do M90 to M112, then the WHIPPLE looks very nice. The 1600AX was quoted at $1500. and there are lots of benefits to it. To get the same cfm as the M62, it would require around a 3.8" pulley or 3.6" (larger than stock M62)...The larger the pulley=less revolutions...less revolution=less heat which gives more dense air, etc etc which means with proper tuning and a 3.3" pulley on a whipple. forged pistons, a whole lot more tuning means one bad ass blown LSJ.
Old Jul 8, 2006 | 06:57 PM
  #36
JerseyJay's Avatar
its a show car, it probably never gets driven enough to see boost anyway, so i really don't see the point.
Twincharging is the biggest waste of time and money on a fwd car. All it does is give you a really incredibly broad powerband that you can't even use half of anyway because you have no traction. A well matched turbo designed to put the power in the useable racing range (mid-high) will no doubt be easier to tune and a lot easier to drive. Lets not forget that torque spike is what kills rods, and torque spike is all you get with a twincharged setup.
Take off the M62, put on a GM racing or Hahn intake manifold, or build your own (4G63 intake manis have identical port spacing, saw off the flange and have a welder weld on the LSJ flange that you can get from GMPP). Then, when your turbo kit is complete, you can sell the whole supercharger setup to an ecotec cavalier owner, or anyone with a 2.2/2.4SS and recoup a significant portion of the cost of your turbo setup.
Old Jul 8, 2006 | 07:01 PM
  #37
JerseyJay's Avatar
you sure thats a "gasket problem" and not a "head flex problem"?
Old Jul 8, 2006 | 07:09 PM
  #38
carbombss's Avatar
look screw all this bigger blower bs i just say say we ditch tha roots an go centrifical then we dont have anything to complain bout yea yea yea i kno it would b alot off $$$$$ but wtf u would make more power
Old Jul 8, 2006 | 09:45 PM
  #39
LittleMT's Avatar
Quite possible the head may lift under high boost, thus requiring the need for a better head stud with a washer that will allowing for proper clamping and even securing of
the head.
A problem found in the SRT circles with the ARP studs as they don't provide aduqate clamping force and the head would lift under extreme boost levels, causing head gasket failures.
Fortunately for the SRT crowd a company called Darrell *** came to the rescue with a
better designed headstud kit that has been tested on a 1200hp drag SRT-4 driven by Mike Crawford. These very studs are in my SRT and so far we have hit them with 38psi from a GT35R Turbo.
The ARP's for the Ecotec 2.0 may be just fine, I will explore this potiential issue when
I rebuild my 2006 SS with better internals....
Old Jul 9, 2006 | 12:55 AM
  #40
Cobalt_Supercharged's Avatar
The build book doesn't mention any head studs other than the one listed from ARP or Bates. I'm assuming they use the same ones all the way to the 1400hp drag car. They run higher compression and 21 PSI on the Phase 5 Cobalts. I would think that it is the head gasket failing, assuming that Selfinfliction used the studs listed in the build book.
Old Jul 16, 2006 | 09:03 PM
  #41
brianteel's Avatar
using the M90 would be a good upgrade from the M62. it will not give gains like the whipple does but it will increase power alot. at the same boost level the M90 will out perform. the good thing is that companys make pulleys for them and other parts that could help build performance.
Old Jul 16, 2006 | 10:41 PM
  #42
It also sucks a lot more power in the process. A Whipple W75AX would produce 22 psi while consuming the same amount of power as the stock M62. While still giving a lower charge temp.
Spanky's Monkey
Mar 7, 2016 06:06 PM
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
goaliemo
Sep 28, 2015 01:37 PM
Builttss
Sep 22, 2015 12:42 AM
RedLined
Sep 9, 2015 09:11 PM
