MAF sensor max voltage?
Old Aug 13, 2007 | 12:01 AM
burntorange's Avatar
Hey, what is the maximum MAF sensor voltage that our car reads? I am trying to dial my meth setup in right now and need to know in order to have the full flow set correctly. Thanks!
please, I seriously need help
Last edited by burntorange; Aug 13, 2007 at 12:01 AM. Reason: Automerged Doublepost
Old Aug 13, 2007 | 03:52 PM
help?
Old Aug 13, 2007 | 05:00 PM
zinner's Avatar
Moderator Alumni
MAF is frequency based, the voltage is a constant.
1700 hz is the minimum (idle) and 11000hz is the maximum (WOT redline) you should see.
Old Aug 13, 2007 | 05:03 PM
Witt's Avatar
^^What Zinner said.
If you don't have a MAF translator for use with the meth kit (it converts the frequency signal into variable voltage to allow the meth kit to interpret MAF readings) you'll have to wire it up to your MAP sensor. MAP is 0-5v.
Old Aug 13, 2007 | 08:23 PM
THANK YOU GUYS SO MUCH!!!!!!!!!!! I really needed that information. You two totally made my day. I can't thank you enough
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
