MAFT Question
Old Jun 10, 2006 | 06:57 AM
cybcow's Avatar
MAFT Question
When reading my aeroforce gauge O2 sensor voltage should I just do WOT in neutral and let it bounce off the rev limiter to see my highest value? I noticed I'm running a little rich as the exhaust is slightly black.
And otherwise I can't find the post where the maft directions are posted so I can change my settings accordingly. (not at home so I don't have my manual).
Any help is appreciated, thanks.
Old Jun 10, 2006 | 09:38 AM
cybcow's Avatar
Bump.
Old Jun 10, 2006 | 12:09 PM
cybcow's Avatar
Anyone?
Old Jun 10, 2006 | 01:35 PM
WopOnTour's Avatar
That wont help you much during Power Enrichment (eg @ WOT)
For road loads it would be better to log your LTFT values.
+ numbers indicate the system is having to enrichen your mixtures to correct for an indicated LEAN condition
- numbers indicate the system is having to lean out your mixtures to correct for an indicated RICH condition
All the factory narrow-band O2 voltages can really tell you is that you're RICHER or LEANER than 14.7:1
Despite a lot of speculation out there, the actual O2 voltages achieved cannot really indicate HOW RICH or HOW LEAN you are.
If you're tuning with HPT (or a MAFT) you ideally should be using a wide-band setup
HTH
WOT
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
