Making the LS4 TB driveable
We all know this mod has some issues when it comes to being touchy. I'm currently using the 4950 scaler. I know some have used this to help things I've also cut the boost completely until 4250rpm and then it comes on at 20% and ramps up from that. The boost cut did help some.
I think tommorow im going to try setting the scaler to 5500 to see if that makes a difference i know on zzp's site for where they are selling it they have listed they tested it that high.
Also torque management, is this a possibility? I have an 07
well if you repin it shouldnt it take care of any problems one may encounter? im not speaking from knowledge im just asking for referance... i was told that the scaler shouldnt even have to be touched if it was repinned.
To explain to the confused guy, the area scalar tells the ECM when the throttle is open X%, what volume of air should be flowing through it. If it expects X CFMs at 10% throttle, but is seeing 1.5X CFMs at 10% (since the larger TB will flow more at the same throttle percentage), it can do many things, including at the extreme thinking there is a vacuum leak, and put you in limp mode.
If you tell the ECM the TB is bigger than it really is, it will open the throttle less per the same pedal travel since it is trying to get X CFMs at Y pedal travel.
I hope this made sense....And I hope what I said is accurate, but this is my understanding how it works.
I have been wanting to do this mod, but my tuner said there will be not point. If there was a dyno of JUST the TB and it was worth the money to power, I would sacrifice some driving for it. But some have said they have gotten used to it.
Staying tuned for more results on this thread.
Now really interested.
eh I did not like it at all on my car, yeah WOT throttle was a little better, but driveability sucked, and for a car that sucks already (I hate the drive by wire crap). It wasn't worth it, plus ****, making 440whp/400wtq on the stocker.
