Making the LS4 TB driveable
Old Apr 22, 2009 | 08:40 PM
  #51
ebristol's Avatar
Originally Posted by Rodimus_Prime
whatever happened to anyone making a new intake manifold for us?
Not worth it on the M62. But you might want to get yours ported by OTTP.
Old Apr 22, 2009 | 09:03 PM
  #52
Rodimus_Prime's Avatar
they do that? never saw anything on that, anything would be a help at this point
Old Apr 22, 2009 | 09:28 PM
  #53
Area47's Avatar
Rent me! per hour
port the head first. manifold is not the problem.
Old Apr 22, 2009 | 09:34 PM
  #54
drew1991sf's Avatar
the ported head is supposed to be a key part in a build. thats wat ppl say is holding the car back.
colejjones is selling one fyi
Old Apr 22, 2009 | 11:04 PM
  #55
Ryze's Avatar
Originally Posted by Area47
some of you need to learn how physics work before you go making huge claims.
Can you explain your intake reversion? How did you know it was intake reversion? how is this caused by the TB?
Old Apr 22, 2009 | 11:31 PM
  #56
Area47's Avatar
Rent me! per hour
air backing up through the blower.
Old Apr 23, 2009 | 12:31 AM
  #57
coopn8r's Avatar
Basically with a Ported Head along with the TVS then you would recommend the ls4 as a must??
Old Apr 23, 2009 | 04:58 AM
  #58
HondaHater's Avatar
I have a question about my LS4.......I seem to have lost 5 MPG. I thought the LS4 leaned the motor out a bit because of more air going in. All thats been changed in my tune is the scaler since installing it.
Please let me know soon what I have to do to fix my MPG if that's possible
Old Apr 23, 2009 | 11:56 AM
  #59
ebristol's Avatar
I dyno tested one for them on my OTT Stage 1 kit. Lost 1hp and 5tq along the entire power band. They cut open the IM and ported the ports to the Laminova cores to about 17mm. I did see a small decrease in my IAT2 temps however.
Josh said that other people have reported gains of 15whp with different power adders. IE. TVS and turbos.
This is so true is should not ever be debated ever again. At least to how it applies to the M62. GM did an excellent job building a IM for the M62 on the LSJ.
Some people may experience this problem with larger power adders then the M62. Tubros and TVS blowers push out more air then the ports to the Laminova cores can handle. So the air gets backed up before the cores. That makes the TVS work hard to push the same amount of air into the IM and to keep the charged air from return back through the rotors.
Contact Josh for more info.
Old Apr 23, 2009 | 01:13 PM
  #60
As far as the MPG drop thats to be expected when essentially your using more throttle than before at all times, you can try to dial in the MAF and lean things out a bit, add some spark advance where you can
As far as a ported head goes thats a bit more involved than I know how to do and quite honestly I dont know any shops around here that I'd trust to do it and it hardly seems worth putting a head on and ignoring the pistons which are the real weak point in the motor. At that point your looking at alot of downtime and a motor build. I'd rather leave the Cobalt alone and put that money into something a bit more classic
Old Apr 23, 2009 | 01:26 PM
  #61
coopn8r's Avatar
Actually just about everything on our cars are relatively easy to do if you're mechanically inclined. I recently did a Piston Swap and it wasn't as bad as I thought.. Had a few snags, but overall its been pretty smooth.. If you were just doing a ported head.. You could do it over the weekend easily as long as you had all the bolts and parts you needed there. If you busted ass you could finish it in a day, but thats if you know exactly whats going on..
The pistons aren't as bad as everyone makes them out to be as long as the car is taken care of with little detonation and a great tune. This is coming from a guy that just blew his #4, but still. that one was totally my fault :P
Old Apr 23, 2009 | 01:58 PM
  #62
thats the kinda thing i would want help with and observe
Old Apr 23, 2009 | 06:37 PM
  #63
chevysssc's Avatar
so if i "bust ass" i can finish in a day?
Old Apr 24, 2009 | 03:09 PM
  #64
i know how to rip ass lol
Old Apr 24, 2009 | 03:12 PM
  #65
coopn8r's Avatar
Nice Rodimus :P Hows the ls4?
Old Apr 24, 2009 | 03:19 PM
  #66
im out of methanol again so i cant do any further tuning until i fill it up again
Old Apr 26, 2009 | 08:22 PM
  #67
HondaHater's Avatar
ok i filled up my tank.....17mpg!!!!!! thats 8mpg down from when i didn't have the LS4 on. I was getting 25-26 w/the GM tune. WTF is going on???? I know more power more fuel....but um....it's like i got a damn leak in my tank!! rediculous......whats been done in my tune was told earlier in this thread....please help!!!
Old Apr 27, 2009 | 12:44 AM
  #68
yea something isnt right there I got 37.5 last night pure highway, driving like a tool with 120mph blasts on the way down to Dave and Busters I still got 32-33
Old Apr 27, 2009 | 12:47 AM
  #69
HondaHater's Avatar
holy ****....come tune my car!!!! i'd love an increase!! right now i can't afford 17 mpg....so i'm parking it until i can get the tuner guy to fix it. it just really sucks......i'm bummed out about it.
Old Apr 27, 2009 | 12:51 AM
  #70
SlowBalt_06's Avatar
the table that was supposed to be changed...the value or whatever was changed to 4950 on hondas car
Old Apr 27, 2009 | 01:11 AM
  #71
liolixli's Avatar
I love mine, but I got methanol and the rebel intake on at the same time. The car is a lot nicer to drive now. It just takes times to learn to drive it again. I wouldn't go back, but I couldn't verify how much difference just the TB made because all the changes were at the same time.
The guy in my signature did a great job tuning for mine. Other than some minor issues, which can be corrected with driving adjustments (likely mechanical and not tune related) the car runs better all around than it has at any point since I drove it off the lot.
Old May 5, 2009 | 04:08 AM
  #72
HondaHater's Avatar
I ended up installing my 60s. Using a OTTP tune that we tweaked a bit for the LS4....my car runs awesome.....I don't have a WB (yet!) but my shitty narrowband isnt peaked at rich anymore...it's actually stoich to just a hair into the lean. Going to sell my 42s and get a WB...but be easy on it until then just in case
Here's the other things we did to it:
turned tq management off
redline to 7200 rpm
speed limiter to 250
ac cut off at 75% throttle
50% boost in 1st
LS4 scailer to 3950 (wayyyyyyyy less touchy now!!)
Added 2 deg. of timing at WOT....no KR!!!
I would try a lower number than 4950 for sure......the driveablity, at least for me, is much much better...even livable....@3950
Old May 5, 2009 | 10:08 AM
  #73
Tennpenn83's Avatar
it's interesting to see that setting the ls4 scalar to less then 4500 would make it less touchy... hmm?
Old May 5, 2009 | 02:48 PM
  #74
HondaHater's Avatar
with it set at 4950...at least for me.....it was either grandma driving or about 70% throttle. hard to manage something in between. with it at 3950 i can at least manage a good amount of in between.
Old May 6, 2009 | 01:57 AM
  #75
Area47's Avatar
Rent me! per hour
the lower the scaler the slower the tb closes. opening rate does not change.
