max boost in first gear
Not sure if this topic was covered here yet. I tried looking around the site and couldn't find anything.
Anyone else just getting around 6psi in first gear?
I was watching some Cobalt videos, and it appeared that they were hitting full boost in first.
Just curious.
Just curious.
Originally Posted by codyss
If I go WOT in 1st I get 10psi and alot of tire noise.
is everyone else on here getting 10psi in first gear?
Originally Posted by MarcS
Hmm.. not sure if something is wrong. I'll have to look more carefully this weekend.
only looked once but i don't think i was very high in boost in first. you go through that gear so fast, and trying to pedal through the wheel spin i don't really pay attention to how much boost is getting down.
Maybe I should get my pcm reflashed. I must be bleeding off boost in first for some reason.
i noticed something today as well. i was driving in traffic for about 10 mins. pulled onto an offramp and there was a celica gt driving and i figured i'd run past him real fast. my temps were over 200, and when i was in third @60mph, the car just wouldn't pull like it normally did. it felt like i was in 4th gear. when i drove down the road for a while and temps got back down to about 185 it ran fine.... that's some serious control that pcm has over the engine i'm guessing
Sounds like something is definitely wrong man. From what I've heard, the SC should be able to hit almost full boost in 1st gear. I could see it being normal if you were only getting 10 or something, but 6 PSI is just way too low under any circumstances.
If its hitting full boost in the other gears, then I'm assuming that your gas is fine, so bad gas can be ruled out. Could be something with the PCM I suppose. Has it only hit 6PSI in 1st since you've had the car, or only recently??
Because if its only started doing it recently, you might want to check out this thread about boost leakage:
Link
Good luck, hope you can find out what the issue is
Link
Link
Link
Na, it's always done it. I think it's either the PCM or the gauge wont read correct for some reason. When I drive it there is plenty of power still.
I figured it was either something with the PCM or it just happened recently, because when you took me for a ride in the SS, it sure felt like full boost
Ok I see. Definitely sounds like something related to the electronics then.
i get between 8 and 10 in first gear but i wish is was less cause maybe then i wouldn't have such traction problems. I'm leaving for english town in like 2 hours hopefully i can get into the 14's
i only see around 6 or 7 in first too, i did check that hose and it was stuck between something, and had a hard 180 degree turn in it so i gave it a bigger loop, but won't be able to test it untill tomorrow because of the rain.
I'll check my hoses again to make sure. I do hit full in 2nd and sofourth so I'm not sure still. I emailed GM about this issue and I'm waiting for a response from them.
i can now hit 10 in first with hella lot of wheel hop lol but i think the hose wasn't flowing right.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
