Max timing with 2.7 pulley 60lbs inj and 91octane
Old Apr 27, 2007 | 08:35 AM
julien performance's Avatar
Hi guys does somebody have an idea of what kind of timing a SS can support with 91 octane and 2.7 pulley with 60lbs injectors
Old Apr 27, 2007 | 08:42 AM
yellowcobaltss05's Avatar
depends how good of a tuner you are
Old Apr 27, 2007 | 09:17 AM
Thanks guys , rigth now i have around 11-11.5 , i heard that lot of people broke a piston this winter , and i know that the fuel here in Quebec at winter time is not even near 91 octane , so i didn't want to take any chances .
Old Apr 27, 2007 | 09:29 AM
if you want to learn a little about tuning talk to Ljavy17 bc he is an awesome tuner
Old Apr 27, 2007 | 11:43 AM
How much power you made with your 2.5 pulley
Old Apr 27, 2007 | 11:45 AM
Ljavy17's Avatar
I say 16 to 17, I was able to run 17.5 on the 2.8 with no knock. So you might be lucky to get about 17, 16 probably more than likely at around 6k without knock.
I say,
14,15, 15.5, 16
Starting at around maybe like 4k
Old Apr 27, 2007 | 03:45 PM
can i send you a mail with a map and a log of this car , i'm only able to do 200hp at the wheel on a mustang dyno look at the timing iM commanding around 16-18 degre and the log is showing 11 ? i should at least do 225whp ,
2.6 pulley
60lbs injectors
typhoon intake
Magnaflow muffler
i can send you a dyno sheet if you want
Last edited by julien performance; Apr 27, 2007 at 03:45 PM. Reason: Automerged Doublepost
Old Apr 27, 2007 | 05:43 PM
Area47's Avatar
Rent me! per hour
I say,
14,15, 15.5, 16
same here.
start low, remember kiddies timing does affect a/f ratio
Old Aug 4, 2007 | 12:23 PM
Jmc007's Avatar
2.6 pulley
60lbs injectors
typhoon intake
Magnaflow muffler
Stock intake manifold, stock downpipe and 2.6" pulley are not a good match. You probably get a lot of knock retard @ 5000+ RPMs ...
Old Aug 4, 2007 | 12:42 PM
braineater's Avatar
i could check and see what my guy did but i am not sure if it would help since i am running a 2.8 and 60#s
Old Aug 4, 2007 | 12:44 PM
KillerBee's Avatar
I think 93 is the best fuel to use cause dont 94 have alchole in it
Old Aug 4, 2007 | 01:06 PM
Doc's Avatar
Doc
Definately upgrade the exhaust...
DarrenGC
Forced Induction
Jan 2, 2016 09:10 PM
Builttss
Oct 4, 2015 10:21 AM
roth
Sep 26, 2015 12:16 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
