maxing boost gauge with 2.9
Old Jun 15, 2008 | 07:44 PM
chood711's Avatar
Whats up guys,
I am hitting over 20 psi(according to boost gauge and 20.4 on intercepter) with my 2.9 I know that this is not possible so what could be the problem? A guy I know said vacuum leak. so should i get some carb cleaner and spray the lines until it idles up or what?
thanks in advance
Old Jun 15, 2008 | 07:55 PM
CobaltSS 16's Avatar
Clogged cat.
Old Jun 15, 2008 | 07:56 PM
04redline0124's Avatar
Clogged cat.
/thread
Old Jun 15, 2008 | 09:08 PM
07 SS/SC's Avatar
Yep I would have to say you have a clogged cat. I had the same thing happen to my car, GM will replace it.
Old Jun 15, 2008 | 10:35 PM
SlowBalt_06's Avatar
yea more then likely a clogged cat but if you have a buddy with the same boost gauge try his to make sure its the gauge
Old Jun 15, 2008 | 10:38 PM
ecotecon18s's Avatar
make sure your intercooler pump is working...mine gauge would hit up to 20psi while huffing non-intercooler air into the motor...put in a new pump, and only saw 17 from then on with a 2.85 pulley
Old Jun 15, 2008 | 11:22 PM
Perfect.disguise's Avatar
Yeah, I see 15 from a 2.9.
Old Jun 16, 2008 | 11:17 AM
chood711's Avatar
i have an interceptor gauge that says same thing. The car still pulls hard. so I should just take it to chevy?
Old Jun 16, 2008 | 11:18 AM
JohnsRallyYellowSS's Avatar
yes, if its under warranty, take it!
Old Jun 16, 2008 | 11:24 AM
CobaltVenomSS's Avatar
yea mine is clogged and my exhaust sounds like this
http://i7.photobucket.com/albums/y29...=slicks012.flv
cant even hear exhaust at high RPM....just sounds like a whooshing noise
Old Jun 16, 2008 | 11:31 AM
CbYellowSS's Avatar
no cat ftw
Old Jun 16, 2008 | 11:34 AM
SS/SCking's Avatar
Go cat-less!! Im seeing 16.5 with a 2.9....
Old Jun 16, 2008 | 11:45 AM
chood711's Avatar
thought about it. could i just go to the exhaust shot and have them cut the cat and weld a pipe on there in its place..gottta save my money, im going on vacation in 3 weeks. cant splurge on a catless dp.
Old Jun 16, 2008 | 12:31 PM
CbYellowSS's Avatar
just take your dp off and clean out your cat that way and put it back on lol
Old Jun 16, 2008 | 12:41 PM
chipsgt's Avatar
Agreed on the cat.
I saw 16 lbs. when I had my 2.9
Old Jun 16, 2008 | 04:05 PM
fmxr47's Avatar
a muffler shop, is not allowed by the state to remove a cat from a car that came with one from the factory if they are e-check certified(meaning that an e-check station will recommend them to you to fix your problem)
Old Jun 16, 2008 | 04:10 PM
06ss2nv's Avatar
yea ur cat is stopped up same thing happened to me
Old Jun 16, 2008 | 05:15 PM
brett5's Avatar
yup just get rid of the cat theres no room for cats in cobalts!!they belong in the barn
by the way my car pisses everyone off it so loud i love driving down the road and getting looks of disgust from everyone i pass its truley great
Old Jun 16, 2008 | 09:51 PM
quicksilver41's Avatar
If you want to go cat-less let me know and I will get you hooked up. There are only 2 shops that will do that around here that I know of. An they both are the best in town.
Old Jun 16, 2008 | 11:49 PM
restonSS's Avatar
sometimes the loudness gets annoying tho. i had a 2.5 inch turbo back exhaust on my turbo scion tc. it sounded bad ass, but got annoying just driving around after a while.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
