it may be a stupid question but...
Old May 19, 2007 | 02:04 PM
braineater's Avatar
i was looking at the stage one kit for the supercharger thats suppose to bring it from 205hp to 236, as far as i can tell its just injectors?
http://www.cobaltperformanceparts.co...roducts_id=287
Old May 19, 2007 | 02:06 PM
AjSS's Avatar
Yea, and a tune.
Witt's Avatar
It also includes a new calibration that increases the redline of the engine and higher maximum boost, since now the upgraded injectors can support higher airflow.
Old May 19, 2007 | 02:12 PM
JKennedy1612's Avatar
Just do a stage 2.
Here: http://www.gmpartsdirect.com/results...umber=17803229
Old May 19, 2007 | 02:15 PM
braineater's Avatar
ahh, well a friend of mine can tune my car (already has once to increase the redline and such) so i could just get new injecters for 200 or so and save some money right?
Old May 19, 2007 | 02:23 PM
cblt12's Avatar
yes sir but he will have to retune it
Old May 19, 2007 | 02:24 PM
AjSS's Avatar
^ If your going to go that route, then buy a hub and smaller pully too, like a 2.9 or 3.0in
Edit: Intense has a modular pully system for $100, that comes with whatever size pully you want. Then you can get extra pullies for $60. There are other places too.
Old May 19, 2007 | 02:27 PM
Witt's Avatar
Correcto.
Rescale the "Injector Flow Rate" table for the new injectors, remove some of the supercharger's torque management and raise the redline and you have yourself a near-GM Staged tune.
Old May 19, 2007 | 02:29 PM
braineater's Avatar
cool, cause i wanted to upgrade but i didnt want to spend the money on a full stage one or two at once, good to know that i can do it bit by bit.
Old May 19, 2007 | 02:30 PM
Mikey851's Avatar
If you aren't worried about warranty then don't buy the GM stage kits. You can get a similar setup for a few hundred less. It is a good kit, but the reason why most people have them is because if your dealership installs it they won't have a reason to deny you service. Although some still do.
Old May 19, 2007 | 02:44 PM
braineater's Avatar
ahh, well i have no skill at all with this kind of things but even i could change injectors, so i dont see any point in paying GM to do it, and enless they can prove that the mod is what caused the problem they cant void your warrenty just for upgrading parts. at least thats what the sticky on this site about warrentys says
Old May 19, 2007 | 02:45 PM
Red2.4SS/SC's Avatar
you can just buy my used ones if you want
105 shipped , all you need is the harness
Last edited by Red2.4SS/SC; May 19, 2007 at 02:45 PM. Reason: Automerged Doublepost
Old May 19, 2007 | 02:57 PM
braineater's Avatar
i will keep that in mind, what kind of injecters and about how many miles on them?
Old May 19, 2007 | 03:05 PM
Mikey851's Avatar
You pay GM to do it because they have to install the tune for you, and don't forget about having to press off the stock pulley and press on the hub.
So, if you're already going to go there to get the tune anyways, then why would you try to install it yourself? If you have a good dealership it will only be a little more expensive for them to do the whole job. What there's no point in is trying to save $150.00 by installing yourself and then having to fight later on to protect your investment in the car, because they will try to blame you.
You'd be suprised how many people "Could change the injectors" and really screw up doing it. I'm not trying to be rude at all, just giving my opinion based off of facts that I've seen.
Edit: I'm talking about if you get the Stage II kit. With the stage I kit I wouldn't take it to the dealer; especially if you have a friend that can actually tune. You are right about the fact they have to prove the aftermarket part caused the problem but answer this: If you had a problem with your engine and you have a 2.8" aftermarket pulley on, would you take it to the dealership as is, or would you swap your stock pulley back in?
Old May 19, 2007 | 03:14 PM
braineater's Avatar
yeah i just mean a stage one at the moment. a friend of mine can tune it so i dont really need the dealership for anything. as far as the pulley goes he can and has done that as well but from what i understand getting the pulley off is a pain ass so i wouldnt ask him to do it enless i slipped him some cash.
Old May 19, 2007 | 03:23 PM
AjSS's Avatar
You can rent a pully puller from zzp to remove the stock pully.
Old May 19, 2007 | 05:11 PM
Mikey851's Avatar
True. I keep forgetting about that.
Old May 19, 2007 | 11:01 PM
Johnboy12358's Avatar
I am still trying to figure out is up with that picture you have, about medium rare steak
Old May 20, 2007 | 10:21 AM
braineater's Avatar
what, dont you like steak? mmmmm steak!
Old May 20, 2007 | 10:30 AM
light'bolt's Avatar
If you already have someone to tune it, might as well go with the 60# injectors and the 2.8 pulley
Old May 20, 2007 | 10:57 PM
I love steak, I just dont understand the three dancing dudes
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Extremespeed
Sep 29, 2015 04:34 AM
