mecanic or electric gauge
Old Sep 5, 2006 | 04:49 PM
yangee's Avatar
my boost gauge is in KPA beacause I lived in Canada and I want to change in psi so I want to know if the original gauge in my cobalt was electric on mecanic and what is the size. For example 2 1/16" (52.4mm)
I want this model do you think it will fit..
http://www.autometer.com/cat_gaugede...earch&gid=3458
thanks
Old Sep 5, 2006 | 04:59 PM
05REDROCKET's Avatar
electric and 2 1/16
it will work but you will need to run the mechanical lines
you can put any gauge you want but
correct me if Im wrong guys
No other gauge other the the stock one will plug into the GM conector
Old Sep 5, 2006 | 07:07 PM
yangee's Avatar
Originally Posted by 05REDROCKET
electric and 2 1/16
so I need a electric one the mecanic one will not fit???
Old Sep 5, 2006 | 10:45 PM
SpecialK's Avatar
FI you want plug and play you'll need to keep the stock one. Maybe you cna talk to your dealer aboot that.
But honestly a mechanicla gaudge would be the better performing gaudge if your gonna spree for a automeeter gauge might as well make it perform better than the stocker did.
Old Sep 6, 2006 | 12:52 AM
Matty's Avatar
thanks
Look into the Aeroforce gauge. I got mine from Intense Racing and it is in PSI plus does a whole lot more. There is splicing involved so it is not a complete direct fit. There is a how-to for it in that section.
Old Sep 6, 2006 | 03:52 PM
yangee's Avatar
I fund this one http://www.crateenginedepot.com/stor...P1586C108.aspx but I need to be shure is in PSI and not in KPA....
Old Sep 6, 2006 | 06:34 PM
zinner's Avatar
Moderator Alumni
The orignal gauge is electric and specific to the GM PCM, it's a PWM based gauge, I think getting the American PSI based gauge would do the job like yangee says.
Old Sep 6, 2006 | 08:28 PM
I got lucky I'm in Canada and I got a PSI gauge.
Old Sep 6, 2006 | 08:31 PM
sheek360's Avatar
kpa is much more precise, why not keep it?
Old Sep 6, 2006 | 08:38 PM
Mase's Avatar
not sure, but you might be able to simply change the background of the readings. Just take it apart, scan the background and change values by dividing everything by 6.895. As for the mechanical gauge I have one running off the boost bypass line. Although it gives a lower reading than the one I get in HP Tuners.
Old Sep 6, 2006 | 08:42 PM
The gauge is a one piece unit yyou can't take it apart.
Old Sep 7, 2006 | 08:55 AM
yangee's Avatar
because the number are to close to see the boost and I'm not good in kpa mode....all my last cars was in PSI. its like pound and kilo....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
ernnyyes
Oct 2, 2015 05:16 PM
Sep 27, 2015 08:53 PM
