Meth Nozzle Placement
Old Jul 15, 2012 | 08:29 PM
MyOtherSS's Avatar
Hey everyone, I plan on buying the devils own stage 1 kit and I am wondering where people are placing their nozzles BEFORE the supercharger. I was going to buy the zzp throttle body spacer with the meth tap but I heard that it's better to place it further back in the intake piping because it has less of a syphoning effect. Anyone know if it really makes a difference? Would the check valve be enough or would i need to run a solenoid?
Old Jul 16, 2012 | 04:35 PM
TStone's Avatar
Definitely run a check valve and just get a throttle body spacer from ZZP
Old Jul 16, 2012 | 10:04 PM
06cobalt racer's Avatar
yup u NEED a check valve. i also use a throttle body spacer
Old Jul 16, 2012 | 10:29 PM
MyOtherSS's Avatar
maybe i worded that wrong, I'm was wondering if i would be better running a solenoid over a check valve.
Old Jul 17, 2012 | 02:26 PM
heres mine in the intake
Old Jul 17, 2012 | 02:49 PM
100% METH's Avatar
There are a variety of placement methods.
The preferred placement method is pre supercharger; allowing maximum atomization and cooling.
If you aren't looking to spend a lot, this article offers a good bit of information.
mounting water injection nozzle in silicone
Old Jul 18, 2012 | 01:32 PM
MyOtherSS's Avatar
Thanks for the help, debating running it from the trunk or tapping the washer tank. How did everyone that is running from the trunk get the wires to the engine bay? Drill a hole in the trunk to run the lines through?
Old Jul 18, 2012 | 01:34 PM
aikidoshadow's Avatar
I ran the wiring following the battery wiring from the trunk. it ran across teh passenger side through the seats on teh passenger side.
Old Jul 18, 2012 | 01:36 PM
volsfan92's Avatar
Theres little holes every where for wires..shouldnt have to drill..I use zzps throttle body spacer for nozzle
Old Jul 18, 2012 | 10:32 PM
i have my line running beside the drivers side door. under the plastic that holds the carpet
Old Jul 18, 2012 | 10:35 PM
bluebalt07's Avatar
I ran the wires behind the back seat and under the door sill trim and out the grommet in the firewall.
Old Jul 19, 2012 | 02:08 PM
mine are tucked nicely under the car from the trunk along the frame. been through 3 new england winters no issues this way
Old Jul 19, 2012 | 02:15 PM
OttawaMark's Avatar
Can a case be made for running post blower? I was thinking a double tap on the IM with 2 nozzles or even the zzp blower spacer with the 2 ports. I know the m62s are cheap and bfd if the coating peel off or the needle bearings spin, but has any cobalt owner tested pre and post blower logging?
I'm buying hrrfreeks AIS kit, not against pre blower at all just wondering if similar IATs could be achieved with a dual nozzle post blower setup.
Old Jul 19, 2012 | 02:19 PM
100% METH's Avatar
It's the same result; your only creating more work
Pre blower atomizes the mixture better, and cools the blower.
Old Jul 19, 2012 | 11:32 PM
bluebalt07's Avatar
^this. He's the expert plus there's a lot of people that have run their m62's for a few years with meth pre blower and still have all the coating on their rotors and the bearings are fine
Old Jul 19, 2012 | 11:46 PM
Running it pre blower also saves some heat wear and tear on teh blower itself I would guess.
Old Jul 26, 2012 | 01:12 PM
MyOtherSS's Avatar
How did you get the lines to exit the trunk? Drill a hole or use a pre-existing one. I was going to just tap the washer fluid tank but i want everything to be accessible.
Old Jul 26, 2012 | 06:15 PM
THere are holes in the floor that are sealed with little metal tabs like a heftier version of the seal on a bottle of pills. lol Pull that one out and you can run your line from teh trunk outside underneath the car.
Old Jul 27, 2012 | 02:34 PM
mine we drilled two holes, and its sealed with this putty like material. been that way 3 years through new england winters daily driven. no issues!
Old Jul 28, 2012 | 10:33 AM
MyOtherSS's Avatar
Ok cool, I was worried about that living in NH.
Old Jul 28, 2012 | 10:34 AM
MyOtherSS's Avatar
You think this would be effective on the stock plastic intake or am I better off just buying the ZZP throttle body spacer? I don't have an aftermarket intake and don't really plan on getting one.
Old Jul 28, 2012 | 12:54 PM
100% METH's Avatar
I would just buy the spacer.... I've tapped the plastic intake before, but then you have a hole in your oem intake.
Old Jul 28, 2012 | 01:58 PM
my original setup was tapped.
Old Jul 28, 2012 | 10:25 PM
OttawaMark's Avatar
One guy I know tapped the underside of the blower itself between the TB and the bypass plate.
Old Jul 29, 2012 | 12:07 PM
euthanasia's Avatar
This is why we dont use spacers for our set ups remember? lol Shrouds the spray pattern of the nozzle.Alcohol injection systems - YouTube
