Meth vs E85
Old Mar 16, 2011 | 03:37 AM
Josuizzle16's Avatar
Meth vs E85
Don't know what either is.. ???
Old Mar 16, 2011 | 03:55 AM
yellowss7590's Avatar
E85 - made from corn 85% ethanol, higher octane suppresses knock. some places hard to find too.
Methanol - usually mixed with water raises octane, cools cylinder temps. also suppresses knock. easily found at race shops.
Old Mar 16, 2011 | 04:00 AM
do they help alot?? At all? Which is better?
Old Mar 16, 2011 | 09:16 AM
alleycat58's Avatar
On their own, they don't do much of anything. Actually on its own, the car won't even run on E85. They're both things used in conjunction with a tune to help increase power.
Old Mar 16, 2011 | 09:19 AM
Kyle4236's Avatar
actually isnt vince claiming he managed to get 100% E 85
Old Mar 16, 2011 | 09:28 AM
alleycat58's Avatar
Yes but running E85 requires tuning was the point I'm trying to make. If you just pull up to the pump and put it in the tank without a tune, well, good luck with that.
Old Mar 16, 2011 | 09:30 AM
Zero6LS's Avatar
E85 is prolly a better bet tho IMO. A little easier to get and doesn't need to be mixed
Old Mar 16, 2011 | 10:09 AM
xnigelx's Avatar
didnt we come to the conclusion that meth eventually eats the coating off the super charger?
Old Mar 16, 2011 | 11:37 AM
G11's Avatar
G11
plus you have 80lb injectors and those would be fine for e85...just depends on availablity
Old Mar 16, 2011 | 12:12 PM
Bluelightning's Avatar
Got Bewst?
Maybe if you run 100%
Old Mar 16, 2011 | 12:18 PM
SCcobaltSS's Avatar
E85>Meth
I have had both and this is my conclusion. Meth was great and all for IATs and such but I have seen a pump failure and clogged line blow two motors on meth. E85 is E85 yes they have different blends dependiong on the time of year but that is not enough of a change to not be able to run the same fueling and timing and damage the motor, from what I have seen, if you run 100% and damage the motor on one WOT pull.
Old Mar 16, 2011 | 12:21 PM
ecot3c inside's Avatar
not if you have the fitting on the blower spacer, doesn't cause that much damage.
Old Mar 16, 2011 | 12:33 PM
JHans5774's Avatar
If I had an e85 station close to me I would drop my meth kit today it is quite the hassel and you do run into problems when your pump dies on you trust me I know from experience
Old Mar 16, 2011 | 12:37 PM
I'm planning on spraying, will they effect anything if I decide to go E85?
Old Mar 16, 2011 | 01:08 PM
SCcobaltSS's Avatar
E85 will turn back into corn at those temperatures.
Old Mar 16, 2011 | 04:32 PM
i like meth because when mixed with water it COOLS lol. its not even hard to mix either. and like all the others said that i forgot to state is no power gain will be shown unless you T00n.
Old Mar 17, 2011 | 12:37 AM
JHans5774's Avatar
Its not hard mix at all I run a 90/10 mix its just one more thing to worry about but it does allow you to run a hell of a lot more timing
Old Mar 17, 2011 | 02:49 PM
CanadianCobalt's Avatar
For those of you who have had pumps died/clogs, what would you do to remedy this or prevent. Any telltale signs, I'd like to get rid of my spare tire and put in a meth kit but I never even thought about the risk of that.
Joel
Old Mar 17, 2011 | 02:56 PM
Omnigear's Avatar
just stay on top of the kit, just like an oil change. just check it monthly ...
Old Mar 17, 2011 | 04:52 PM
Tennpenn83's Avatar
Old Mar 17, 2011 | 10:21 PM
JHans5774's Avatar
No way to prevent it just watch your wideband on wot pulls that's how I noticed mine was out
Jan 12, 2016 12:01 AM
Builttss
Oct 4, 2015 10:21 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
