Milk at the bottom of the stick...
Old Jan 5, 2010 | 09:42 PM
terry11's Avatar
Headgasket...? It's just a tad at the bottom of the stick. It's the exact same color as the crap i'm getting out of the pcv valve so now i have a breather on that and the oil cap. Should i put a catch can on or do you think it will be ok the way it is?
What else could cause that milky junk. It has to be moisture from somewhere, and it has never drank coolant. The oil was just changed about 3 weeks ago and i didn't notice any milk y anything in the oil.
Anything I should check? Maybe change the oil again and see if it comes back...
Old Jan 5, 2010 | 11:58 PM
redline4's Avatar
Water in your oil man.
Old Jan 5, 2010 | 11:59 PM
JL-KA's Avatar
yup...water
Old Jan 6, 2010 | 12:02 AM
redline4's Avatar
You've either cracked something, or a gasket is bad.
Old Jan 6, 2010 | 01:26 AM
Flatgod's Avatar
That's bad news. You drive through any massive puddles lately and have bogging issues after? Other wise I'd say your hg is fuct. Do a compression/leakdown test.
Old Jan 6, 2010 | 11:19 AM
Cobalt_Daddy's Avatar
eeep i just sold my grand am with a blown headgasket for $500 good luck with that man defiantely water in your oil :/
Old Jan 6, 2010 | 01:07 PM
RednBlack's Avatar
the compression check will help, but for me it came back good and my hg was still blown. leakdown test might get some results if the compression check does not.
Old Jan 6, 2010 | 08:18 PM
BlueStang's Avatar
Sounds like it would be water
Old Jan 7, 2010 | 06:37 PM
terry11's Avatar
What could have i cracked...
Old Jan 7, 2010 | 06:41 PM
boost_junkie16's Avatar
If you do alot of short trips with your car when it's cold it might be just condensation.. We see alot of it at the garage this time of year. Check your coolant and make sure it's not starting to look like there is oil in it. If your coolant is clean then there is a good chance that it's just condensation. Take it for a 20-30 minute drive once a week or so and it should prevent it. Good luck.
Old Jan 7, 2010 | 06:47 PM
redline4's Avatar
Well it could be a of things... w it being so cold up there you could have easily got to much water in the block and cracked the block. Or it could easily a engine internals causing it. But its probably just a bad head gasket.
Old Jan 7, 2010 | 11:46 PM
StevesBlack06's Avatar
you could be pumpin coolant through your intake mani aswell... do you have a dual pass or have you ever taken your intercooler endplate off? those o rings on the cores and the endplate gasket can stretch if you have had them off, allowing coolant to pass through your intake mani directly into your head... also did your coolant level change? did it get lower? thats the first thing i would check... is there white smoke coming out of your exhaust? thats a tell tale sign of a blown hg.
Old Jan 8, 2010 | 12:07 AM
mrbelvedere's Avatar
or quit giving your car protien injections
Old Jan 8, 2010 | 12:13 AM
aww yea, mega man shakes dnt work on cars bro... or humans for that matter...lmao
the lubricity properties just arent there... sorry
Old Jan 8, 2010 | 12:31 AM
i wasent talking about shakes
Old Jan 8, 2010 | 01:21 AM
terry11's Avatar
lol well i did feed her some z max a few days ago and thought that may be it. But doubtful...and my coolant is still completely full and really clean like always. Thats what i was thinking condensation, it has been super cold last couple weeks. i work outside all day so i feel the pain my car is going through :P
I do have the fans running all the time and my operating temp never even hits 180 during the winter. Think that has anything to do with it? I can't see how i would have cracked the block, and i have never had the end plate or intake mai off.
I'm gonna change the oil again tomorrow and keep checking it. if it comes back i'll know something is def up. the top of the valve cover is perfectly clean like always too. I mean as far as i can see with a flash light. You would think it would be everywhere if i did have water getting in the oil.
Old Jan 8, 2010 | 11:55 AM
what did you do w your used oil... if you can drain it into a milk jug or somethin it will seperate over time. then you can see if its water or coolant.
Old Jan 9, 2010 | 11:18 AM
damien's Avatar
My bet is it's just condensation.
Old Jan 9, 2010 | 03:40 PM
Tennpenn83's Avatar
check your headbolts by taking off the valve cover. there are 10 main headbolts and i know of a few cases where these have failed, including my own. they are TTY (torque-to-yield) and can stretch if there is too much stress in the combustions chambers, and the head starts to lift.
the head gasket is fairly stout for a stock piece. they are MLS (multi-layer steel) and very rarely are they the problem
Old Jan 9, 2010 | 06:56 PM
terry11's Avatar
Ok i will do that tonight. I'm gonna change the oil again and set the old stuff in a jug to see if it separates. How will i be able to tell if the head bolts failed? What am i looking for? I was going to go with the ARP head studs when i do the valve springs and neutral delete shafts, but wasn't planning on that for a while yet
Old Jan 9, 2010 | 07:28 PM
well if they are loose they have streched beyond service limits
Old Jan 9, 2010 | 08:14 PM
Tennpenn83's Avatar
head studs are never a bad idea. i have seen stock headbolts fail at lightly modded levels. think stage 2.
if they have stretched, they will be loose. mine were loose, i could loosen them the rest of the way by hand (and i would have, if they weren't so damn long)
they should be tight enough that you can't budge them (obviously)
Old Jan 10, 2010 | 08:33 PM
terry11's Avatar
Head studs were tight, and there was only a small amount of milk that collected around the valve cover gasket. I doubt very much it's the HG. It must just be condensation. Checked my plugs too they were burning good. Cam lobes also look awesome. I'll just keep checking it periodically to make sure it doesn't get worse
Oct 21, 2015 11:57 PM
CudaJoe
Oct 5, 2015 11:56 PM
jcarroll53
Sep 24, 2015 07:43 PM
Cptnslo
Sep 24, 2015 09:32 AM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
