Minimum to reduce engine movement
Old Jun 24, 2010 | 11:53 AM
chris88z24's Avatar
Originally Posted by TurboTechRacing
Were you on the J-body.org back in the day? Did you have a Z24 (assuming yes, by your name?)
Sure did, I had a blue 2nd gen phase 1
I was on v6z24 a lot more, though, since the org was mostly 3rd gens.
Old Jun 24, 2010 | 12:35 PM
Redefined1's Avatar
go ttr solid upper mount and poly inserts for the trans. yes there are vibes but its not as bad as people make it seem.
Old Jun 24, 2010 | 02:32 PM
blackss2.0's Avatar
Do you guys think that these would be worth it? https://www.cobaltss.net/forums/parts-66/60s-ls4-tb-m62-raw-cai-ttr-sway-2-7-ss-sc-wheels-poly-mounts-boost-gauge-219002/
Old Jun 24, 2010 | 04:41 PM
selfinfliction's Avatar
no way i would use poly inserts over the TC mounts, #1 they're USED, #2 they give vibes, #3 the brand new TC mounts are the same price as those
Old Jun 24, 2010 | 04:56 PM
blackss2.0's Avatar
Other people have been saying that the t/c mounts are only a little stiffer though and don't do much. Convince me ha. Right now I have three possible routs around the same price range. 1. Used ttr upper engine mount + ced t/c mounts 2. ottp stage 1 mount or 3. used ttr upper engine mount + used polly mounts. What do you think?
Old Jun 24, 2010 | 06:04 PM
Redefined1's Avatar
ttr upper mount with poly inserts
Old Jun 24, 2010 | 06:11 PM
Brenticus's Avatar
wait. from your mod list it only looks like you have gms2 equivalent. i was about to go ottp stage 2... am i going to tear **** up if i don't go with mounts first?
Old Jun 24, 2010 | 06:28 PM
TurboTechRacing's Avatar
Mounts are always a very good idea to do right away.
Old Jun 24, 2010 | 06:46 PM
blackss2.0's Avatar
Ive broken two down pipes so far from normal street fun but I keep wheel hop to a minimum by driving it cautiously in first which is why I haven't gotten traction mods yet. Its definitely pretty important to get some traction mods if you wanna track your car or launch it hard so you don't break an axle or something even worse.
Old Jun 24, 2010 | 08:56 PM
JCobalt's Avatar
i have the zzp mid length header and down pipe,and i broke six down pipes. i finnally had the exhaust shop move the flex pipe to the bottom of the down pipe like were the factory one was and had him move the cat to the top of the down pipe. i havent broken one in a year, and i used to break them like every two months.
Old Jun 24, 2010 | 09:07 PM
  #36
i don't need to convince you into anything, as it's not my car, and i'm not making any money on anything, and the thread title is
MINIMUM TO REDUCE ENGINE MOVEMENT
if you're not looking for the minimum, get a set of $300 mounts and don't ask for the "minimum" because there's always going to be a big gap between that and higher end parts.
Old Jun 24, 2010 | 11:04 PM
  #37
blackss2.0's Avatar
True... After reading a bunch of threads I went from wanting the minimum to wanting a permanent solution to fix engine movement and wheel hop. Ill either do a ttr upper engine mount along with t/c mounts or just stage 1 ottp rotated mount. Not sure yet.
Old Jun 24, 2010 | 11:10 PM
  #38
Brenticus's Avatar
so do you guys think a ingalls stiffy would be enough for a while after i get the ottp stage 2?
Old Jun 24, 2010 | 11:51 PM
  #39
JCobalt's Avatar
my wheel hop was pretty coservative with the ingals on the stiffest setting w/ a 2.6 on the stock blower with 270 whp. i also had 50 percent boost cut till 4000 in 1st gear though.
Old Jun 25, 2010 | 12:04 AM
  #40
Brenticus's Avatar
got to thinking just now if it would be bad to have flex tubing before and after the cat?
Old Jun 25, 2010 | 12:16 AM
  #41
JCobalt's Avatar
that would probably just be a waste of time and money
Old Jun 26, 2010 | 11:42 AM
  #42
Brenticus's Avatar
i thought you were the one who said the flex pipe was better at the bottom? if it doesn't restrict flow to have 2 and it's not too expensive than it would probably be a good idea.
Old Jun 26, 2010 | 08:27 PM
  #43
JCobalt's Avatar
i dont think its necessary to have two
Old Jun 26, 2010 | 09:31 PM
  #44
blackss2.0's Avatar
Why not just put the money into mounts that will prevent it from breaking?
Old Jun 26, 2010 | 11:25 PM
  #45
Brenticus's Avatar
I plan on it eventually. I just have a guy who does real good exhaust work for 1/3 of what everyone else does it for.
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
OPCrer
Sep 27, 2015 08:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
