Missing my torque
Missing my torque
Got my gm stage 2 installed and love it. Thought a nice vibrant 3" exhaust would compliment it. But thats a big negative. Definatly pulls harder at high rpms but cant cruise up hills anymore with low rpms. Anyone else have a similar set up? What should i do next.......
This is due to losing exhaust velocity at lower rpms... this happends due to using a 3" exhaust on a setup that does not flow enough air to utilize it... It actually hinders performance.
The only real option is to live with the reduced torque or switch back down to a 2.5-2.75" exhaust. I've actually been contemplating that myself.
As for taking advantage of it - 2.7" (or smaller) pulley and 60# injectors. That's my next step.
Thats exactly what I was thinking, I would prefer this. Just get a smaller pulley if you "need" it back.
Lower torque helps you get out of the hole better
Smallest I'd recommend on 42s is a 2.9. Anything below that and you're going above 100% IDC.
When you switch to a super big exhaust without dropping down a pulley or two you're just alleviating all the backpressure that the stock system creates. The engine now is more efficient because it can push all the air through faster then with the stock exhaust. By adding more boost it just creates that whole cycle again with not being able to push it through fast enough.
It helps you not hop while launching, but at the same time means you have to launch harder to get a reasonable 60' (and I still haven't found that sweet spot yet). Though I admit it feels like it's pulling a lot harder on the top end now.
Ok when you larger you are pushing out more air, but that is not always good. Exhaust needs to scavenge to work properly, if the exhaust is too large then you will lose some low end, but you should gain it back at a higher RPM. Bigger is not alway better if you dont have the HP to utilize the larger exhaust.
My turbo setup is getting a 3.5" catless DP into a 3" catback. I want 20 psi to spool like no tomorrow.
If you can go with as big of an exhaust as you want, why is he losing low end? The scavenge process doesnt seem like it is happening until later in the RPM range... He has a 3.1ish pulley, not a 2.8. The 2.8" might be able to handle the large exhaust, hence why he is losing low end.
I bet the OP could get a better 60' time than most people with more low end torque because of less wheel spin and hop. This is my experience, when I had less torque I could get a better 60', until I got used to the extra TQ and learned how to launch, but then I was back to the same 60' time (******* street tires!), that was until I got DR's ofcourse.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
