mods needed for 2.6
mods needed for 2.6
alright here are my mods now
injen cain
gm stage 2
ingalls torque dampener
(coming in)
cti header and downpipe
corsa touring
im wanting to run a 2.6 pully soon but im wanting to get all the boost out of it
what mods will i need to do to be on the "safe side"
injen cain
gm stage 2
(coming in)
corsa touring
Originally Posted by Sp00ner
injectors... other than that, you should be fine. You can get away without the injectors, but I wouldn't...
sounds tooo simple
Along the same lines here, I'm looking at going 2.6" pully too, I don't have any work done on this particular car yet, would I be able to just get the 2.6", smaller belt and adjuster, 60# or 65# injectors, and a HPtuners tune? Is that a "safe" set up?
I'd be expecting to do Clutch, Flywheel, and drive axels as they come up in the future though.
so then my question should be, what size injector is required to run at 80% efficiancy on a 2.6" pulley?
depends on ur mods. on a complete stock car, meaning no intake or exhaust or nothing you should see 18-20. if you have exhaust work done it will be less if you have intake or ported blower it will be more
