which mods are next?
Old Dec 19, 2009 | 07:36 PM
joe_589's Avatar
right...
current mods
full 3" with 200 cell cat and 4-1 manifold
ported head
+1mm wasted stem valves
dual valve springs
piper cams (266 if i remember correctly)
m62 supercharger
75mm intake pipe with a KnN cone
courtenay sport custom remap
VXR injectors
Full aluminum radiator
full size pre rad with twin fans
custom charge cooler header tank
eagle rods
rebore with low compression bigger weseco pistons
balance deletion
lightened flywheel
4.17 gearbox
now for my next mods i am thinking blower cams.. also a overdrive pulley, however have read bad things about some of these so i will be getting a custom hub made up out of stainless steel which prevents wear and tear to the oil seal
the question is what is next after the crank pulley and new cams?!
standalone ecu and harrop i know off but anything else?
any need for a bigger throttle body?
many thanks for your help
Joe
Old Dec 19, 2009 | 07:46 PM
Snakes709's Avatar
Originally Posted by joe_589
right...
current mods
ported head
dual valve springs
m62 supercharger
VXR injectors
eagle rods
balance deletion
lightened flywheel
4.17 gearbox
Joe
IMO i wouldnt get the pulley. I havent had it happen to me but i heard bad stories of them not being balanced right and it screws the motor up.
As for the tb...i cant really comment on that, never messed around with it. I seen people make nice gains from porting it. But then people are saying the LS4 is way to touchy.
Old Dec 19, 2009 | 07:50 PM
joe_589's Avatar
i have been assured by the company making me a one off pulley that using a stainless steel hub will prevent oil seal failure so will see what happens, if i dont decide to go for it then will get a lightened pulley to go on instead
ls4 is this a bigger throttle body? worth the hassle then or not?
thanks
Old Dec 20, 2009 | 11:59 AM
joe_589's Avatar
bump!
Old Dec 20, 2009 | 01:11 PM
Snakes709's Avatar
iiunno, i cant answer that for you. I never had the LS4 TB...some people liked it but most people hated it because its way to touchy...you can play around with the tune to get it to settle down but iiunno. I say just port it. Some guy did on here and gained 6hp just from porting.
Old Dec 20, 2009 | 01:35 PM
joe_589's Avatar
hmm just port the oem throttle body then... 6hp seems alot!
i take it that everyone is still heavily against porting the sc!
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
