motor mount
Old May 23, 2010 | 03:33 AM
Killa702's Avatar
motor mount
my motor mount just broke today i dont know how, and my axle broke and also my oil pan, this was all at once.
does anyone know where i cant get motor mounts for cheap?
and is there a how to on it?
thanks
Old May 23, 2010 | 03:37 AM
northvibe's Avatar
which ones? the side mount, rear mount, front trans mount? junk yard, or CED sells OEM parts.
Old May 23, 2010 | 03:47 AM
Killa702's Avatar
the front passenger mount
Old May 23, 2010 | 02:50 PM
Killa702's Avatar
Old May 23, 2010 | 02:56 PM
trey ss's Avatar
jus buy a solid mount and stg 1 axels and call it a day
Old May 23, 2010 | 03:24 PM
Killa702's Avatar
yea im buyin solid mounts from zzp and tranny mounts and stage 1 axles also.
hopefully with this upgrade ill be good for a while.
Are the 2 motor mounts the same?
Old May 23, 2010 | 03:27 PM
trey ss's Avatar
naw there is like 4 differnt mounts top motor mount, side, and 2 trans mounts, im pretty sure
Old May 23, 2010 | 03:31 PM
Killa702's Avatar
yea, so the side motor mount and top arent the same? cuz at zzp i only saw the top motor mount
Old May 24, 2010 | 06:24 AM
Killa702's Avatar
Old May 24, 2010 | 02:03 PM
jsscriado's Avatar
Old May 24, 2010 | 02:04 PM
rallyracer's Avatar
Im pretty sure all 4 are different and that only 3 of the 4 have aftermarket replacements.
Old May 24, 2010 | 02:18 PM
Dainslaif's Avatar
Correct.
There's top (the passenger one the OP is talking about), front tranny, rear tranny, and Side. Top, Front Tranny and Rear Tranny have aftermarket options available, side is only through GM, but I've never heard of anyone replacing that one because it's a huge PITA to get at.
Old May 24, 2010 | 02:28 PM
jsscriado's Avatar
Ok so I should just replace the top ones? The passenger one and driver side one?
Old May 24, 2010 | 02:47 PM
Dainslaif's Avatar
If you're upgrading your mounts, you can only purchase a top and the 2 tranny mounts. The other one is just an OEM replacement (and you'll never really need to replace it).
I have a TTR poly top mount powdercoated black for 165 shipped if you're interested.
Old May 24, 2010 | 05:17 PM
TurboTechRacing's Avatar
thanks
Might want to checkout www.TurboTechRacing.com
Old May 24, 2010 | 06:28 PM
jsscriado's Avatar
I want to buy both. Do they come with the bolts?
Old May 24, 2010 | 10:27 PM
Factory bolts can be re used.
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
n20saturn
Sep 30, 2015 12:26 AM
