mounts
Old Oct 7, 2009 | 12:19 PM
  #51
N8s07SS's Avatar
I guess I'll try this thread since no one responded in the other one:
So am I still the only one that has had fairly bad vibes and only slightly less wheelhop than stock with these? I mean it's got to be a bent frame or something--I've tried everything else you guys have suggested that might be the cause of it not working (tire pressure, CABs, loosening & retightening the mounts, etc.). I just really don't see how my frame could be bent from being backed into in a parking lot? I'm almost ready to take mine off and try to sell it, because based on everyone I've talked to, my experience is very unique and a different car would most likely have better results. Oh yea, I only have the stage 1 mount & spacer, but I am also 95% stock (drop-in filter). Thanks for the help, and if anyone thinks they may be interested in a OTTP stage 1 rotated mount, let me know.
Old Oct 7, 2009 | 12:29 PM
  #52
ShortStack's Avatar
Check the bolts and make sure they are secured.. someone came on here bitching then when ott told them to make sure they tightened everything correctly he got mad... then came back and said "oh yea it was able to be turned by hand"..
Old Oct 8, 2009 | 08:42 AM
  #53
N8s07SS's Avatar
I can guarantee that I don't have loose bolts. I have loosened and retightened all the bolts on ALL the mounts 2 or 3 times already, and I have all the correct torque specs as well.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
