Mp90 3800
Old May 8, 2013 | 09:58 PM
07ssBOOST's Avatar
Question Mp90 3800
will this bolt on to our cars or will it need an adapter ? im fairly certain it will need an adapter and saw a few threads about mp90s workin on our cobalts but will this series 3800 work? found one for a good deal and if so may invest in it
Old May 8, 2013 | 10:11 PM
BankerBalt's Avatar
more money than it's worth IMO. you have to modify the supercharger iirc
Old May 8, 2013 | 10:19 PM
07ssBOOST's Avatar
i saw a few threads where some said it was a direct bolton then others saying you need an adapter plate, and some saying it only cost around 600 all together to get done, i can get the SC for about 300
Old May 8, 2013 | 10:34 PM
Blairwolf's Avatar
Euthanasia on here makes an adapter plate for it. You also need to have the bypass port on the intake endplate welded shut. MP90 has an internal bypass.
edit- I think you would need a different snout drive then the one from a 3800 but i am no expert.
Old May 8, 2013 | 10:44 PM
07ssBOOST's Avatar
how dificult would you rate this swap at on a scale of 1-10?
Old May 8, 2013 | 10:59 PM
Tjolley's Avatar
U sure u didnt find a m90 not a mp90 theres a big difference.
Old May 8, 2013 | 11:13 PM
In for answers cuz ive thought of this before. For the price no matter what i bet its better than a 2.4k tvs
Old May 8, 2013 | 11:21 PM
07ssBOOST's Avatar
ive found both, whats diff on them??
Old May 9, 2013 | 02:21 AM
wayfarer's Avatar
Buick M90 decidedly NOT a bolt on. Ignoring any drive pulley location issues, here's an M90, no idea what year, with an LSJ gasket lined up at the discharge port for bolt hole reference
Old May 9, 2013 | 02:23 AM
Melon's Avatar
U need to swap snout and have adapter plate made for it. Jr makes them. Idk wut he charges. I have one of his kits 2nd hand tho and am putting it on this summer
Old May 9, 2013 | 02:32 AM
100% METH's Avatar
the 3rd gen m90 off a 3800 will not work with out some serious modification.
The 4th gen MP90 from magnuson has a universal four bolt design at the outlet.
-1/2" aluminum adapter plate
- inlet adapter too TB
- weld bypass shut (MP90 has an internal one)
- 6 3/4" snout iirc... or was it 6 5/8"...
- minimum of 60 lb injectors required
Melon's Avatar
I believe inlet needs tweaking too
Old May 9, 2013 | 02:40 AM
100% METH's Avatar
thats what the 90mm - 75mm/66mm inlet adapter is for
has to be clocked 60* iirc
Old May 9, 2013 | 03:10 AM
footballplaya3k's Avatar
If you go M90 you want a Gen 5, none of that Gen 3 garbage. A guy on clubgp made an adapter to get you guys' TVS to bolt up and he gained like 40whp. The M90s really not worth it.
Old May 9, 2013 | 03:48 AM
OttawaMark's Avatar
Should have my MP-90 any day now
mccullj
Jul 7, 2010 10:17 AM
Cobaltss/TC
64
Mar 27, 2009 05:44 AM
ralliartist
Drag Racing
Oct 15, 2008 01:40 AM
j27
Mar 15, 2008 10:36 AM
