My car just turned off on the freeway need help
Old Oct 22, 2007 | 12:03 AM
Slowbalt SS05's Avatar
I was driving back from the so cal meet and my car just turned off, I turned it back on and it was koo. Why do you think my car turned off.
Old Oct 22, 2007 | 12:07 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it happened to me when the car only had 550 miles. i just turned it back and never had an issue with it again.
Old Oct 22, 2007 | 12:08 AM
2.4SlowassBalt's Avatar
idk take it to the dealer and see if they can find anything
Old Oct 22, 2007 | 12:10 AM
I just went over the 36 thousand mile warranty, I got the car used. What should I do?
Old Oct 22, 2007 | 12:13 AM
beamSS's Avatar
did you hit a bump. do you have key chains. it happened to me twice. when i hit a bump the key turned and engine shut off.
Old Oct 22, 2007 | 12:21 AM
I think I did hit the key when I was giving my girl my phone on the freeway, could that have done it?
Old Oct 22, 2007 | 12:22 AM
zinner's Avatar
Moderator Alumni
No check engine light?
The 05's had some weird and intermittent issues.
Old Oct 22, 2007 | 12:25 AM
nop no check engine light on.
Old Oct 22, 2007 | 12:27 AM
MarcS's Avatar
The Stig
My car used to shut off if you unlatched the steering wheel and slammed in down as far as it would go. A reflash fixed that.
Old Oct 22, 2007 | 12:30 AM
NinjaHampster's Avatar
this happend to me but mine wouldnt start back up so i had to replace the fuel pump fuse
Old Oct 22, 2007 | 12:49 AM
thanx. i will look into that. i just hope it is not something expensive.
Old Oct 22, 2007 | 12:52 AM
ItalianJoe1's Avatar
Used to happen to my buddies 05, but nothing was ever found and it hasn't happened in a while. Happend to me on 3 occasions over 2 years, I replaced the crank position sensor and it has been good so far, but only time will tell.
Old Oct 22, 2007 | 01:35 AM
REIGN SS's Avatar
Original Hayden Fanatic
...i dont want to know who figured that out
Old Oct 22, 2007 | 02:16 AM
Doc's Avatar
Doc
Let us know how it turns out. Had a great time btw....the smoke from the fires was real interesting. A first for me.
Old Oct 22, 2007 | 02:23 AM
Avrj123's Avatar
it happened to me a few times usually after hitting a pothole supposedly it is a safety feature thats triggered in case of accdents but going over potholes might shut it off also.
Old Oct 22, 2007 | 02:57 AM
Kaisoboy's Avatar
Had that happen to me when I hit a bump in the road from unleveled pavement. It was a very aggressive transition in the road and when I hit it I thought I blew both tires and f**ked the front end up. The car shut down but started right back up again.
Old Oct 22, 2007 | 04:14 PM
Mattman6's Avatar
yes if you turn the key to the off position it will cut the car off, if you do not have a CEL or running problems. Then most likely it is nothing at all.
Old Oct 22, 2007 | 08:17 PM
Thanks for all of you guys help guess ill find out thru time, if it continues I just ask for some HELLLLPPP.
vjoel2011
Oct 2, 2015 12:11 PM
Wind
Sep 11, 2015 06:57 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
