My Last Thread Everyone Please Help!!!
Old Jun 19, 2007 | 09:10 AM
dylan1221's Avatar
ok as some of you might know i have been posting on here the past couple days. about my hahn racecraft 3 inch catback that i just got. i will be installing it today with a friend i dont know much about cars but i deff should be able to do this if u guys say its as easy as it is.
i attached 2 pics of the exhaust and it came with a bag i guess with a gasket or spacer of some sort and of course the nuts and bolts and washers. now my question is can anyone give me an easy explaination i can print out or something that i can use so i can do this easilyy and tell me if i have enough parts to put it on. Thanks everyone i really need to get this beast on!!!!!
Old Jun 19, 2007 | 09:13 AM
Dead Zen's Avatar
its really easy man. cut the old exhaust at the bend in the pipe right after the rear twist beam and unbolt the 2 bolts at the cat. Lube the rubber exhaust hangers with wd-40 and they will slide right off, old exhaust off. install new gasket at cat and the exhaust.
Old Jun 19, 2007 | 09:33 AM
dylan1221's Avatar
Thanksss Come On Everyone Bump!!!!
Old Jun 19, 2007 | 09:54 AM
chevysalesman614's Avatar
exhausts are an easy install. even if you don't understand the directions, you should still be able to do this with none. jack the car up (or on a lift) and have a look. you'll kick yourself for asking, once you see how easy it is.
Old Jun 19, 2007 | 09:58 AM
dylan1221's Avatar
im just confused about the cutting so behind the rear axle ? so close to the muffler?
Old Jun 19, 2007 | 10:02 AM
PuSha050's Avatar
u cut the old exhaust to get it off the car.. its not split in two like ur new exhaust
Old Jun 19, 2007 | 10:13 AM
dylan1221's Avatar
bump.
Old Jun 19, 2007 | 10:16 AM
Acidangel_5.0's Avatar
******.. get your ass under the car and work and stop acting like a 12 year old.. do it or sale the parts.. seriously man.. we should not have to tell you how to do something like this.. its like putting gas in your car..
Old Jun 19, 2007 | 10:17 AM
PuSha050's Avatar
now im confused like denny.. why are u bumping? everything you need to know is answered.....
Old Jun 19, 2007 | 10:32 AM
Dead Zen's Avatar
illustration:
CUT HERE
thats it. about 2 inches from the muffler. sawzall would be good to use.
Old Jun 19, 2007 | 10:34 AM
OrngBalt's Avatar
Can we please? This has gone far enough. I haven't even bought an exhaust or ever done one and I know what to do by now.
Old Jun 19, 2007 | 10:35 AM
dylan1221's Avatar
thank YOUUUUUUUUUUUUUUUUUUUUUUUUUU thats all i wanted to know
Dead Zen's Avatar
and also not to be mean but if you cant pull off the simple mod of a cat back maybe you should pay someone to do it and any future mods.
Old Jun 19, 2007 | 10:40 AM
dylan1221's Avatar
so make cut first , hangars down , unbolt , take down then bolt back up
Old Jun 19, 2007 | 10:41 AM
Dead Zen's Avatar
yeah. that easy. took me literally 15 mins.
Old Jun 19, 2007 | 10:42 AM
dylan1221's Avatar
ok thanks guys sorry for sounding retarted im really not just one of those kids that dont wanna hurt the balttt..
Old Jun 19, 2007 | 10:44 AM
D4u2s0t's Avatar
this is probably the SIMPLEST thing you can do, but i won't be a dick about it. Ok, here ya go. if this doesn't answer it, please, please take it to a shop.
1) get car off the ground somehow, will be easier to work
2) loosen bolts connecting stock exhaust to downpipe (2 or 3 bolts.)
3) exhaust should now be loose, minus the hangers which will just slide off.
4) when you try to take off the stock exhaust, you will see where it needs to be cut. you will think to yourself "damn, how in the **** will i get this over the rear axle." if you don't know what the rear axle is, you will say "Damn. how the **** will i get this over that bar thingy". that's where you cut.
5) the exhaust will now pull right off.
6) take the new exhaust, connect the hangers
7) loosely tighten (i guess that doesn't make sense, but make snug not he-man tight yet) the2 or 3 (can't remember, pretty sure it's 2.) bolts connecting the new exhaust to the downpipe. make sure you use a new gasket, which should have been included. (i think you called it a spacer)
8) put the 2nd pipe on, again fitting everying in the hangers.
9) once it all lines up right, tighten everything.
10) start the bitch up, take it for a test drive.
11) after driving for a while, you may need to re-tighten everything. if you value your fingertips, let the car cool down.
12) that's it.
i'll cover it now, there may be some smoke, and it's probably going to smell like your car is on fire for a while. it's normal. it's the oils burning off of the new pipes.
Old Jun 19, 2007 | 10:48 AM
dylan1221's Avatar
thanks again D4u2s0t
Old Jun 19, 2007 | 10:50 AM
PuSha050's Avatar
12) that's it.
wait wait.. after #9 u forgot some stuff
10) somehow get the car back on the ground
11) wash hands or risk dirtying the car
12) open driver side door and sit in car seat
13) put key in ignition, press clutch and turn key
you got the rest right
Old Jun 19, 2007 | 10:51 AM
D4u2s0t's Avatar
woops!!! yea, i guess it wouldn't be a good idea to drive away before you lower the car.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Builttss
Oct 4, 2015 10:21 AM
riceburner
Oct 2, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
