My LSJ head is ruined :(
When I installed it, the end was moving up and down. After that happened I took it out and it was fully extended. So is that where I messed up? I thought its supposed to be preset.
#41
For the love of god..
The tensioner is supposed to be loose like that when you put it in and then once you start the car it will be exactly like explained.
It has a spring inside to help with the tension so the reason its hard and cannot move is because its working.
Now there is no special way to screw it in.....its a large bolt...righty tighty lefty loosey. Its that simple.
Torque to 55ft/lb and call it a day.
The issue you have is the broken lash adjuster. Fix that first. Its very basic. Remove the old one and put the new one in. As far as I know you just drop it in.
If it still isn't running right then look into the head but first fix the lash adjuster. It has nothing to do with how you replaced the timing tensioner but was most likely a coincidence. Or was the noise initially.
After you fix the lash adjuster and while the valve cover is off and the spark plugs are out id think about rotating the motor a few times just in the off chance there was a skipped timing chain you can see if there is interference.
#42
So it just moved up and down like that then after removing everything such as valve cover, fuel rail, etc. u just screwed it in like that? Didn't have to line anything up or hit on it or anything? Just stuck it in? Lol I'm trying to wrap my head around how I possibly screwed up.
#44
it's a redesigned tensioner.....the old design you had to remove and reset the tensioner. The new ones are hydraulic, so you should just have to screw it in and you are good to go.
#45
I did everything right I guess. What hurt me was prolly when I removed the old one, the zip tie I had connecting the two gears together snapped and the gears must have jumped timing because it was a loud popping sound. -_-
#49
Lol dude there was not broken lash adjuster when I first pulled the valve cover off to install new tensioner. Car was running awesome(except for rattling chain noise) I didn't see it broke until I started car and got horrible noise after installing the new one. Pulled valve cover back off and there it was just laying.
