My M62 E85 car will wax the floor vs most TVS cars on gasoline...
Old 10-13-2009, 03:24 PM
  #151
WickedSS2005's Avatar
*sniff* I taught him well. Proud of you Jordan
Old 10-13-2009, 03:50 PM
  #152
sput's Avatar
Originally Posted by Tennpenn83
of course you could. but it will still ramp the boost (although much quicker) instead of making BAM! 16psi like the m62.
most poeple that have gotten the tvs (myself included) have only been on the stock pulley. i watch the boost gauge make 15, 16, 17, all the way up to redline where it makes 20. when the only other difference was the m62 w/2.8" pulley, you punch the gas at pretty much any rpm and ~16ish psi was instant
Put a smaller pulley on your TVS and make BAM! 18psi and ramp up from there..
Old 10-13-2009, 05:38 PM
  #153
Supporting Vendor
Zooomer's Avatar
There seems to be some confusion on the TVS making less boost than the M62 down low. I think it's better worded that the TVS makes MORE boost up top, not less down low.
With a 2.8" pulley on the M62 and a 3.15" on the TVS, I believe the M62 is effectively a larger blower which would explain the surge. Not to mention, cars with top end power feel like they have less low end.
Old 10-13-2009, 05:44 PM
  #154
sput's Avatar
You can see that pretty clearly in EB's graph:
Originally Posted by ebristol
Red - M62 w/ 2.7"
Blue/Green - TVS 2.9"
They seem to be on par until ~3200 rpm.
Old 10-13-2009, 06:30 PM
  #155
383_Stroker's Avatar
All things equal (pulley, etc).. the tvs would make more boost at every rpm.. k thx..
Old 10-13-2009, 07:50 PM
  #156
ralliartist's Avatar
he's talking about the instant grunt of the m62 vs the slower but more powerful increases from the tvs. the tvs packs way more punch, but its mostly upper rpms, where, with the m62, you punch the gas and BAM!
that makes complete sense, and that's true to what I've seen on MOST dyno's. But the dyno graph that EB posted, shows IDENTICAL hp and tq numbers down low between the TVS and M62, which would mean the car would feel the EXACT SAME, yet the TVS has quite a bit better top end, meaning the car would pull away faster and faster as you climb higher into the rpms.
My point is, John's statement is incorrect. The wheelspin should still be clearly evident as the dyno graph he posted shows the TVS and M62 making IDENTICAL power down low. This istant grunt that would normally not be felt on the TVS, is clearly shown that EB's car still feels exactly the same as his M62 did, only with better top end.
Old 10-13-2009, 09:00 PM
  #157
qwikredline's Avatar
how would you know? You never drove a tvs car. and we are not talking about curves, although if you look from 1000 to 2500 its clear even on Erics chart. Tennpenn is correct. and Zoomer. The car does not feel the same TVS to M62, just like these folks are saying (who have TVS) but in the end who cares, you dont have a TVS. meh why bother
Old 10-13-2009, 11:00 PM
  #158
ebristol's Avatar
It will be interesting to see what happens with a 2.7" pulley on the TVS.
Old 10-13-2009, 11:09 PM
  #159
SS/SC Crazer's Avatar
I know I know pick me pick me!!!
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/adams-tvs-build-343-whp-300-tq-190849/
Old 10-13-2009, 11:43 PM
  #160
ebristol's Avatar
Originally Posted by SS/SC Crazer
****! I forgot I have your run files. Let me check it out...
Damit! Your runs did not log boost!
Old 10-14-2009, 12:14 AM
  #161
Tennpenn83's Avatar
that's pretty much what i wanted to say.
no offense ralli, but it's kinda hard to explain unless you've driven a tvs car. it's just a different feeling than the m62. there's much more to it, especially up top, as shown in EB's dyno sheet. but it doesn't just come on instant. i know the dyno sheet says one thing, but actually driving it feels different
there is still plenty of low end grunt, and plenty of punch any time you nail the throttle, but it just doesn't feel the same as the m62. at all.
Old 10-14-2009, 12:33 AM
  #162
lsjwannabe's Avatar
How did you come to that conclusion?
Old 10-14-2009, 01:51 AM
  #163
Rent me! per hour
Area47's Avatar
i can tell ya what will happen
Old 10-14-2009, 10:43 AM
  #164
freakta's Avatar
please do
Old 10-14-2009, 01:27 PM
  #165
Rent me! per hour
Area47's Avatar
power goes up
i did 347 on a fucked up map. 353 on a good map.
Old 10-14-2009, 02:04 PM
  #166
ebristol's Avatar
I was thinking more about the Tq/hp differences or similarities in the low end.
I have sputs 2.7" E85 dyno runs but car made quite a bit lower tq then mine. His timing table is a lot different then mine.
I would think that with a smaller pulley the Tq/hp differences would become more obvious sooner in the RPMs.
Old 10-14-2009, 04:25 PM
  #167
sput's Avatar
Hmm.. no I'm on a 2.9" pulley. Maybe I'll try the 2.7 next year but haven't yet. I need to resolve my fuel issue first.
Old 10-14-2009, 05:12 PM
  #168
Supporting Vendor
Zooomer's Avatar
From the dyno here posted showing the HP the same with a 2.7 M62 vs. a 2.9 TVS.
Old 10-14-2009, 07:11 PM
  #169
no they did not, sorry!
Old 10-14-2009, 07:51 PM
  #170
Tennpenn83's Avatar
i'm assuming this is in the lower rpms, where efficiency is not really of issue
Old 10-15-2009, 03:11 PM
  #171
Supporting Vendor
Zooomer's Avatar
Efficiency is going to be nearly the same at lower boost/cfm levels between the M62 and TVS.
Old 10-15-2009, 03:18 PM
  #172
lsjwannabe's Avatar
Old 10-15-2009, 03:30 PM
  #173
Pyros777's Avatar
Are the dotted green lines supercharger rpm?
Old 10-15-2009, 03:32 PM
  #174
lsjwannabe's Avatar
That is correct.
Old 10-15-2009, 04:21 PM
  #175
Rent me! per hour
Area47's Avatar
dun dun dun!
Quick Reply: My M62 E85 car will wax the floor vs most TVS cars on gasoline...
