My meth install
Old 12-17-2012, 10:41 AM
50/50 boost juice premix
i found this 'nozzle' calculator on here... if its a 2.0liter, max boost is like 18, and max rpms is 7200, says i need a 3.5 gph nozzle?
DevilsOwn Injection
Old 12-17-2012, 10:43 AM
jonathan923's Avatar
nice man, now you can really beat honda civics by a lot with the new set up
Old 12-17-2012, 10:44 AM
ecotaac yo
Old 12-17-2012, 10:56 AM
06cobalt racer's Avatar
talk to 100%meth about what nozzle size you should get.
also the times i posted are for constant spray. so for drag racing it should last awhile maybe 20-25 passes or so. you just have to keep an eye on it.
i would say a 10 gph nozzle is too big. what all mods do you have?
Old 12-17-2012, 11:02 AM
oh i understand you meant constant spray lol trust me
2.8” Pulley, Multiple Pulley System
60# Injectors, gonna swap my #80's in soon
Injen Intake
ZZP Longtube Header/Catted Downpipe Combo
Ottp Stage 1 Heat exchanger
GM Stage 2 Belt
574's Dual Pass Endplate
ZZP Phelonic Manifold Spacer
NGK 1 Step Colder Spark Plugs
GMPP Clutch Upgrade Kit
ZZP Stage 1 Axles
TTR Engine Mount
Powell Race Parts Front Trans Mount
LNF Rear Trans Mount
LNF Shifter Linkage/Throwout Bearing
TWM STS kit
Old 12-17-2012, 11:32 AM
Texas SS's Avatar
Preety cool and unique
Old 12-17-2012, 12:30 PM
EXsoccer1921's Avatar
even if you can only spray for 7 minutes on a tank with your nozzle. thats still ~30 passes at the drag strip
and are people really going to the lengths of using two different tanks and setups just so they don't have to mix them?
Old 12-17-2012, 12:40 PM
Texas SS's Avatar
I think so . And my 1 gallon tank will feed a 7gph :/ should be ok
Old 12-17-2012, 12:58 PM
is that the nozzle u are using? what psi do you have it to start spraying at? and max out?
Old 12-17-2012, 01:13 PM
jvirginillo's Avatar
I like this idea. I was also trying to find a way to mount it up front and this idea never corssed my mind. What size (diameter) pipe did you use? I am going to look at doing the same with the largest diameter which wil fit.
Old 12-17-2012, 01:23 PM
  #36
Texas SS's Avatar
My plan is have it set 10-12psi and max out at 15
Old 12-17-2012, 02:15 PM
  #37
The thickest section i believe was 4". i'd recommend simply taking your grille out and measuring for maximum space without going above where the grille starts
Old 12-17-2012, 04:51 PM
  #38
Silli question but do you have a vent installed in the system? Doesn.t the tank need a way to allow air into the system at the filler cap?
Old 12-17-2012, 05:31 PM
  #39
good point. assuming that the tank is air tight then eventually it will cause a vacuum. it wont take much to vent it though. just a very tiny hole or something.
Old 12-17-2012, 05:41 PM
  #40
deceased10's Avatar
that is one sick settup!
Old 12-17-2012, 06:44 PM
  #41
InfraRedline's Avatar
I ran a 5gph nozzle back on stock blower when I ran meth and had it engage at 8 psi (non progressive) and I had a one gallon tank and after a month it had gone down maybe 1/3 of the way, and that included a trip to the track.
Old 12-17-2012, 07:58 PM
  #42
I was thinking the same. Small hole with a Dremel bit should do it. Thatns for re-affirming what i was thinking.
Old 12-17-2012, 11:35 PM
  #43
yes, forgot to mention that. we drilled a VERY small hole in the cap.
And a quick update: we temp fixed the leak at the nozzle. Took out the red tab thing holding it on. Waiting to payday tomorrow to order a new nozzle, size to be determined
Old 12-17-2012, 11:39 PM
  #44
thank you for the input as always sir! upon checking the 'nozzle selector' on the devilsown website, it said i would need roughly a 3.4 gph nozzle, i'm assuming 5ish should suit my needs.
Old 12-18-2012, 12:44 PM
  #45
kdub1492's Avatar
Pretty cool setup Adam, good job! Wouldn't say this is easier then the trunk mount lol, but def pretty cool!
Old 12-19-2012, 10:51 AM
  #46
i think i might need to get a real tank to keep the fluid from sloshing back and forth with the curvature of the current tank though
ps does anyone know how weather proof the pump is?
Old 03-04-2013, 02:37 PM
  #47
freakta's Avatar
Nice setup
Old 03-04-2013, 04:42 PM
  #48
microgab's Avatar
Go TVS now
Old 03-05-2013, 09:52 AM
  #49
Oh, thats on the list just hard to save a solid 2500 for it thats all
Old 03-05-2013, 01:20 PM
  #50
DarkChild's Avatar
I have a devils own meth kit with a broken controller, tb spacer, lots of hose, and 3 nozzles. if you or anyone is interested.
That's pretty neat though. Oh, a new controller is $150 for a progressive, I don't feel like running methanol.
Quick Reply: My meth install
