View Poll Results: What mod next
Cooling: H/E,dual pass intercooler end plate, meth injection. If this than which one
45.71%
Clutch/Flywheel Brands?
18
51.43%
Other, tell me
2.86%
Voters: 35. You may not vote on this poll
My next mod
Old Dec 12, 2006 | 01:02 AM
Joewit's Avatar
My next mod
What do you guys think I should do next? My cuurent mods are in my sig plus I have the vibrant header/dp ordered and am getting a JBP CAI for christmas. Im thinking something for cooling or a new clutch.
Old Dec 12, 2006 | 01:55 AM
Joewit's Avatar
hmmmmm
Old Dec 12, 2006 | 02:04 AM
ReMz's Avatar
how many miles do you have? cuz it's likely that stock clutch might start going
Old Dec 12, 2006 | 02:06 AM
Joewit's Avatar
9000ish miles and I learned to drive on it. its slips when i shift hard into second from 7000 in first. anyone think installing a clutch in a drive way is a good idea I kinda know what i'm doing and my dad is pretty mechanical and he'd help me. I've heard clutch installs costing $6-700 dolllars
Old Dec 12, 2006 | 07:41 AM
DTM2188's Avatar
I vote for cooling, not sure which one, they all seem to work well. I haven't put my water/meth kit on yet so I can't give any opinions on that either. But if your clutch isn't too bad, then I would go with cooling.
Old Dec 12, 2006 | 11:07 AM
Johnboy12358's Avatar
Personally, I would go with the dual pass end plate, and maybe another heat exchanger. I've heard that when your on that size pulley the s/c makes a lot of heat, so you might want to cool the intake charge...
Clutch is also something that you need to look into I would think
I am by no means an expert, so take what I say with a grain of salt
Old Dec 12, 2006 | 11:19 AM
halfj99's Avatar
if its slipping id go with the clutch...matenence before mods
what good is extra power goign to do you if you cant transfrer it...id look into a spec 2-3 clutch (if there made for you guys yet)
Old Dec 12, 2006 | 11:20 AM
yeah, but, i may be wrong here, but cant high intake temps be a cause of detonation? Clutch is replaceable, but if you fry something because of heat, you're screwed.
again, i may be wrong, i am on the learning curve
Old Dec 12, 2006 | 11:45 AM
Codyak Supercharged's Avatar
your doing 250whp right now? go with the clutch, you wont blow your motor on what you got now, so go build what will break.....clutch. just my .02
Old Dec 12, 2006 | 11:48 AM
CTCOBALTSSS's Avatar
I vote clutch first bro. Cooling is definitly a close second that should be done as well.
Old Dec 12, 2006 | 02:29 PM
Good to know that I am not totally wrong
These forums are such a great learning environment.
I guess I'll have to change my vote, go for the clutch, seems like a heavy majority
Old Dec 12, 2006 | 02:37 PM
Ljavy17's Avatar
COoling, youll notice the diff right away.
Old Dec 15, 2006 | 05:23 PM
Joewit's Avatar
well it seems like clutch is the choice so thats what im going with. Hopefully by the end of february ill have enough money . You guys made good points for both though so I'll definetly do cooling after my clutch.
Old Dec 15, 2006 | 07:41 PM
Blown 4-banger's Avatar
Listen to me! DO NOT DO ANYTHING ELSE UNTIL YOU UPGRADE YOU COOLING!!! HEAT KILLS POWER!!! CLUTCH/AXLES CAN WAIT!!!
Old Dec 15, 2006 | 07:57 PM
e to the x's Avatar
Get your drive train built up first and then do the POWA!
Old Dec 15, 2006 | 10:22 PM
plyboy-illest's Avatar
i agree
Old Dec 15, 2006 | 10:24 PM
Joewit's Avatar
So should I go spec2+ or 3+
Old Dec 16, 2006 | 07:18 AM
Matty's Avatar
I was about to put clutch into the poll but thought how good is making power to the ground when the axles will come into question.
With your mods I say axles.
Old Dec 16, 2006 | 07:23 AM
Allshot's Avatar
I say you go cooling. The last thing you want to do is blow your motor. Then get the clutch and axles after.
Old Dec 16, 2006 | 07:49 AM
Joewit's Avatar
Hmmmm well now im lost I guess i'll save up and do it all at once or not or i dont know.
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
