My potential mini-build list...
Old Sep 4, 2013 | 02:23 PM
Basically what I have gathered from reading all of the mp90 threads was to not bother with it...
yeah slightly but they are cheaper, are still a bolt on, and i kinda wanna just go with that since its slightly against the grain
Old Sep 4, 2013 | 04:04 PM
blueLNFftw's Avatar
I could only find one for sale anywhere currently and you would still need to source a shorter snout for it. Plus you need an IM adapter and TB adapter made for the balts.
Regaurdless, good luck. It would be awesome to see another one.
Old Sep 4, 2013 | 04:14 PM
I got a brfpr and I still have a ton of room on 60s with my 2.8 tvs setup stock head stock block. I think my idc is 64% down from 89% without the brfpr.
And as said above. add pistons to build and rest looks stout.
Old Sep 4, 2013 | 04:21 PM
ThexGovenor's Avatar
If I were to do it over I would port the head and spray and that will get you to your goals. A TVS setup is expensive!
Old Sep 4, 2013 | 06:32 PM
its just unreal how much a tvs costs! worth it... but not when you see a 400+ whp turbo setup for only 600-1000 more.
07 whats a brfpr?
Old Sep 4, 2013 | 08:03 PM
blueLNFftw's Avatar
07 whats a brfpr?
boost reference fuel pressure regulator.
more boost, more fuel
Old Sep 4, 2013 | 08:26 PM
mrbelvedere's Avatar
Originally Posted by 574
If you still want to take a short cut look up zrateds mini build tread and see he didnt take the engine out for piston install. I would and I'd recommend sleeves and rods. But you can get away with buying pistons and total seal rings and not pulling the engine
you need to pull it to get the bores checked for out of round and taper
yeah i think id go that route... of course now that will be pushed further down the line
why cut my own sprocket nubs? dont they come with the full timing set?
no because your cutting the nubs off the stock balance shafts
cryO2 would be a better and cheaper option. plus you can add on the intake air cooling kit, and make a blower spacer to run it through as well.
they don't work that well
Old Sep 4, 2013 | 09:31 PM
oh, right i have read some about that before. now as far as me sticking with the m62 for now, my boost SHOULD go down with the ported head so i shouldnt need to worry about this until i go tvs/mp90
Old Sep 4, 2013 | 10:02 PM
574's Avatar
574
Do your head, Pistons, keep 2.8, E85, 150 shot and thank me later. If I could go back and do it over I would have done a m62/N20 build rather than TVS
Old Sep 4, 2013 | 10:05 PM
Cams will significantly lower boost as well. Plus they make more power throughout the powerband Ive got the dyno proof!
Old Sep 4, 2013 | 10:49 PM
  #36
dont worry, vander nars isnt here to argue the proof lol
Old Sep 5, 2013 | 12:33 AM
  #37
mp90 is not a direct bolt on you need a different snout and an adapter plate
if I could go back and do it over I would have done a m62/N20 build rather than TVS
im smelling some bull **** on that
Old Oct 29, 2013 | 02:41 PM
  #38
ok so i'm back at it still working on my list
im thinking it would be better to go with a ati super damper rather than NBS
Old Oct 29, 2013 | 02:59 PM
  #39
So my list as of now with prices... this really hurts to look at
zzp stg2 cams - 650
pmp head - 400
new timing set - 255
super damper - 400
75# supertech valvesprings and retainers - 359
new rocker arms - 150
supertech valves - 325 (can i just go stock replacement and be fine?)
new lash adjusters - 150
head gasket kit - 200
dynotune - 500
miscellaneous assembly stuff - 100
total ~ 3500 bucks. ouch... i gotta get a loan or something
and if i wanna add pistons, rings or sleeves, machine shop... ahh another 1-1.5k easy
Old Oct 29, 2013 | 03:02 PM
  #40
oh and what about the 2.0 gmr cams?! theres a set for sale now that i might just jump the gun on
Old Oct 29, 2013 | 03:07 PM
  #41
Tjolley's Avatar
Need longer valves. Never seen any made
Old Oct 29, 2013 | 03:08 PM
  #42
what for, to run the 2.0 gmr cams?
Old Oct 29, 2013 | 03:09 PM
  #43
Tjolley's Avatar
If Ur Gona barrow money. Might as well get more and do the entire engine to protect Ur investment.
Old Oct 29, 2013 | 03:13 PM
  #44
Honestly man, I wouldnt borrow money to do a build. Save up what you think you will need, then add 50% problems happen and you want a cash reserve to fix them. ask me why I know.
Old Oct 29, 2013 | 03:32 PM
  #45
eh i was being sacastic i really don't know how to budget this though #personal problems
Old Oct 29, 2013 | 04:54 PM
  #46
574's Avatar
574
Or you buy blues cams and I'll sell you a brand new set of zzp 82 valve springs. thatll save you like $400 right there
Old Oct 29, 2013 | 05:19 PM
  #47
InfraRedline's Avatar
Yep, buy blue's cams, 574's springs, stock valves, save money and be happy. Stock motor isnt even trying at 300whp. I know you are planning for the future, but it really sounds like most of your noises can be addressed in the chain/guides/fasteners department.
I'll be getting my stock motor with ported head and zzp S2 cams out tonight to put in my other car and should be in that 300whp on the ol M62 in my daily/winter car
Old Oct 29, 2013 | 05:34 PM
  #48
JapEatr's Avatar
South Central *********
do exactly this
Old Oct 29, 2013 | 05:43 PM
  #49
574's Avatar
574
See Adam, we are here to support. Now let us help you
Old Oct 29, 2013 | 05:45 PM
  #50
Help us...help you
