My potential mini-build list...
Old Oct 30, 2013 | 04:57 PM
  #101
Staged07SS's Avatar
Administrator
Administrator
I run dual 75# supertechs
Old Oct 30, 2013 | 05:22 PM
  #102
InfraRedline's Avatar
I do agree that it is really nice to have a "back up plan" vehicle in case something breaks, or just so you can take your time on an install.
Engine wise, let it ride. I ran the TVS on small-ish pulleys with a ported head for 3 years and 25k miles (cams this year) and was not easy on the old girl by any means and it never let me down. Pulling that motor out to put in my DD for many miles to come...hopefully lol
Old Oct 30, 2013 | 06:04 PM
  #103
SPDDMN36's Avatar
Sooo many builds going on. Wish I could tear into mine a bit more. Best of luck adam.
Old Oct 30, 2013 | 06:34 PM
  #104
thanks alex. its crazy. lol
ok so now im wondering about the valves. instead of supertechs i think im gonna go with stock replacements. gotta save mula where i can and i dont think there would be a huge gain to be made from 350 dollar valves. hell maybe instead of that i could get a 200 dollar 3 angle valve job done on the head and gain a metric **** ton there.
Old Oct 30, 2013 | 07:02 PM
  #105
574's Avatar
574
Honestly I'd leave valves alone.. Maybe lap them
Old Oct 30, 2013 | 07:16 PM
  #106
JapEatr's Avatar
South Central *********
You dont need valves
Old Oct 30, 2013 | 07:30 PM
  #107
mrbelvedere's Avatar
you do not need new valves or a 3 angle valve job
Old Oct 30, 2013 | 07:36 PM
  #108
kdub1492's Avatar
Listen to this man...
Old Oct 30, 2013 | 08:02 PM
  #109
so use my existing valves? titty sauce. what about total seal rings can that be done while the head is off without dropping the cradle
you guys are making my day. thank you all much! what else can i skip/ use existing parts/ get them cheaper
Old Oct 30, 2013 | 08:12 PM
  #110
574's Avatar
574
If your replacing the rings you should throw some pistons in.. I mean you are THERE
Old Oct 30, 2013 | 08:14 PM
  #111
yehh but then theres machine shop and rebuilding Everything and taking off everything... i want this done this spring not next spring lol...
i saw your rebuild info thread btw very nicely done
Old Oct 30, 2013 | 08:17 PM
  #112
i think rocker arms can be skipped
is ceds 200 dollar gasket kit the best place to get it?
Old Oct 30, 2013 | 08:27 PM
  #113
Staged07SS's Avatar
Administrator
Administrator
No need for valves as the others said.
If anything u can get new valve stem seals, but they are not a req either.
Old Oct 30, 2013 | 08:33 PM
  #114
Staged07SS's Avatar
Administrator
Administrator
ok boys. **** just got real. purchased blues cams.
its definately not 'build time' yet but this is my first step into this, minus lsjion holding my head
Good stuff man. Remember my cam install thread
Old Oct 30, 2013 | 08:39 PM
  #115
ive read that twice today
Old Oct 30, 2013 | 08:41 PM
  #116
Staged07SS's Avatar
Administrator
Administrator
lol, I'll be using it again as well.
Old Oct 30, 2013 | 08:51 PM
  #117
ThexGovenor's Avatar
and why is that?
Old Oct 30, 2013 | 08:53 PM
  #118
hes buying some new gmr cams from a guy that popped up. also hopefully that gmr head!
Old Oct 30, 2013 | 08:54 PM
  #119
Nice! he just has a GMR car.
Old Oct 30, 2013 | 09:14 PM
  #120
Staged07SS's Avatar
Administrator
Administrator
I'm not buying the cams (already have cams). Just getting the head.
Yes sir, a straight GMR car with 2 rare GMR parts (H62 & GMR head).
Old Oct 30, 2013 | 09:16 PM
  #121
ahh man id do the cams too lol i think youd regret not doing it...
what are the specs of the gmrs compared to your stg1s
Old Oct 30, 2013 | 09:19 PM
  #122
Bluelightning's Avatar
Got Bewst?
Don't go with stock replacements. Spend the money on Supertech's. The cams you bought like revs. And you ain't gonna be able to go much for high revs on stock spring's. Well you can, but it's a bad idea.
Old Oct 30, 2013 | 09:23 PM
  #123
Yeah... you are going to need better valvesprings than stock to take advantage of the cams. also may want to consider an ATI or going up a pulley size. Though the 2.8 might be ok at 7500+
Old Oct 30, 2013 | 09:28 PM
  #124
574's Avatar
574
thanks 574 that seems a lot better!
Pmp head - 400
new timing set - 255
super damper - 400
nicks 82's -price tba
head gasket- $60
alan tune- way cheaper than 500...
Miscellaneous assembly stuff - 50
pow!
Old Oct 30, 2013 | 09:36 PM
  #125
replace the sleeves if your putting pistons in and use total seal ap stainless rings
