My potential mini-build list...
Old Oct 31, 2013 | 12:51 PM
  #151
Steviodaddio's Avatar
A.) Am I missing anything
A. Missing a snail.
Old Oct 31, 2013 | 01:50 PM
  #152
574's Avatar
574
True^^
Old Oct 31, 2013 | 02:55 PM
  #153
mrbelvedere's Avatar
Who has that ever happened to? If you spend a lot of time in high revs I could see it but there a tons of people on here who spin their motor up on stock shafts and never seen anything like that. Not saying you're wrong but I think it would take a long ass time for that to happen.
the engine I just pulled apart had 2 spun rod bearings all the mains were **** and the balance shaft bearings are oblonged
I would suspect its more common then you would think that's just one area that gets over looked
A. Missing a snail.
yea right
Last edited by mrbelvedere; Oct 31, 2013 at 02:55 PM. Reason: Automerged Doublepost
Old Oct 31, 2013 | 03:15 PM
  #154
ThexGovenor's Avatar
the stage 2 cams are not at peak power by 7500. If you look at my dyno sheet its still climbing at quite an angle.
Old Oct 31, 2013 | 03:53 PM
  #155
slitterell's Avatar
Why do people over here on css think turbo is the only way to build power?
Old Oct 31, 2013 | 04:02 PM
  #156
because its easier
Old Oct 31, 2013 | 05:14 PM
  #157
slitterell's Avatar
Nitrous is easy too :p but doesn't mean it is for everyone
Old Oct 31, 2013 | 05:23 PM
  #158
nhanson's Avatar
Originally Posted by mrbelvedere
because its easier
Easier doesn't always mean better!
Old Oct 31, 2013 | 05:36 PM
  #159
InfraRedline's Avatar
Let's keep this on topic ehhh? lol
Old Oct 31, 2013 | 06:08 PM
  #160
exactly! id throw a turbo at my car and make an easy 100 hp more than this build will make but id rather have strong internals that can be ridden hard and put away wet for a long time.
i wanna stay supercharged. its why i bought an ss/sc and not a tc. theres just a uniqueness factor to having a screaming sc 4banger that i just love
Old Oct 31, 2013 | 07:39 PM
  #161
nhanson's Avatar
Same here. Love instant power and the whine
Old Oct 31, 2013 | 08:46 PM
  #162
574's Avatar
574
Sc is harder on engines so that's not really a good argument
Old Oct 31, 2013 | 09:47 PM
  #163
Wert842's Avatar
You guys can love the instant power all you want but once the the turbo spools, the bullshit ends.
Sent from my Samsung Galaxy S4 using CobaltSS
Old Oct 31, 2013 | 10:11 PM
  #164
JapEatr's Avatar
South Central *********
I still got plenty of bull ****
Old Oct 31, 2013 | 10:34 PM
  #165
you are completely incorrect
Old Oct 31, 2013 | 10:49 PM
  #166
JapEatr's Avatar
John you have any bs delete sleeves for the inner bearings?
Old Nov 1, 2013 | 12:26 AM
  #167
im not saying sc or tc is better i just said i wanma have a semi built engine that can take some abuse without worrying about internals unlike most people do by simply turboswapping to make a shitton of power.
i dont even care too much about whether the power comes on fast or if it explodes after 5 seconds its all badass in the end
my car is not and will not be the fastest thing on the block. i just want to make good power. reliably. and stay sc because nhra racecars
Old Nov 1, 2013 | 09:18 AM
  #168
no I just buy them from level zero and make my own stubs make sure you lube them up when you put them in or you take a chance of driving the bearing out
Old Nov 1, 2013 | 11:27 AM
  #169
noorj's Avatar
how do you actually install them? Just rubber mallet them in or do you need a hydraulic press?
Old Nov 1, 2013 | 12:13 PM
  #170
a long 1/2in drive extension and a socket as close as possible the same size as the bushing put the socket on the extension backwards lube up the bushing slide it in the block then use the extension and the socket to shove it back into the bearing then use a hammer to drive it in you will want take the tool out after a few hits to look to see if its all the way in if not keep hammering it in
Old Nov 1, 2013 | 12:36 PM
  #171
noorj's Avatar
Thanks John, good info!
Old Nov 1, 2013 | 03:10 PM
  #172
slitterell's Avatar
If you remove the chain drive from the bus and wp, (going ewp) will it be Ok or cause any problems?
Old Nov 1, 2013 | 04:06 PM
  #173
574's Avatar
574
No problem
Old Nov 1, 2013 | 05:10 PM
  #174
slitterell's Avatar
Oops. Bs not bus. Auto correct haha
Old Nov 4, 2013 | 06:31 PM
  #175
ok so bs delete sleeves added to list haha
oh and arp headstuds.
ill be good on stock rockers and rods right
