My potential mini-build list...
that is correct i will be boosting less. as for the s/c making more heat though i think it will, as the ati makes the pulley act like its a size smaller, which i think i will be ok with
The heat is manageable. I am on a 2.7 cams and ported head and not an issue. I am running e85 but you don't see that on the aeroforce. I will be rebuilding the SC and going to a 2.5 before long. I think the heat is from compression of air mostly
well e85 doesnt help with intake temps but more allowing you to burn cooler and run more timing - whole.other thing
what cooling mods are you on?
i got meth injection, intake manifold spacer (gonna ditch it when the heads off since john says so lol) a dual pass, option b and extra heat exchanger
from what i understand the main heat issue is its a small blower being spun past its limits it generally quits making power past 14000 rpms or something like that
I also don't have meth in. E85 does have a cooling effect. It is just not measured because of where it is being injected and the location of the temperature sensor (on map sensor)
Also, I plan to keep the phenolic spacer. It seems to help from what I can tell. Cruising tempo stay around during 10-15 degrees above ambient on the hottest of days
Phenolic spacer? Some claim it doesn't do anything. Others have boost leak issues but the only time I had a boost leak issue was with the crappy zzp gaskets. I got the go ones and have had no issue
Gm gasket
Gm gasket
Isn't all the effect of cooling done by the fuel evaporating? Isn't it completely evaporated from sitting on the valve and combustion chamber temps? I am asking because I don't know
Idk what it is besides a cooler burning fuel either way it deals with different things than intake air temps affected by the supercharger
i may be adding e85 into my build too by the way guys
i'll just need to get some 80#'ers
then maybe i'll make above 280 wheel
i also may ditch the meth injection; its too problematic and hard to tune for; i'd rather just have a kickass cooling system. i may copy mac gen blackwater and throw a fan on the heat exchanger do a flow through setup and call it a day
i'll just need to get some 80#'ers i also may ditch the meth injection; its too problematic and hard to tune for; i'd rather just have a kickass cooling system. i may copy mac gen blackwater and throw a fan on the heat exchanger do a flow through setup and call it a day
