Nates 2.9"=10psi
Old Aug 9, 2007 | 11:20 PM
  #76
rnjmur's Avatar
So when you turn the car to the "ON" position before you start it, the gauge doesn't zero out? If the gauge doesn't zero out then it is messed up.
My gauge did the same thing, read about 10 or so lbs of boost but it was just that the guage got messed up some how. I knew it was messed up becasue when I turned the key to "ON" before I stated it and all the guages would zero, the boost guage was showing -5. Once the dealership installed the new gauge it was showing boost correctly again.
Old Aug 10, 2007 | 03:00 AM
  #77
Super_SS's Avatar
same problem...problem figured out for those who wanted to knw wat it was...
BOOST GAUGE BROKEN...hahahahah..was worried alot...
also is the gauge under warranty?
Old Aug 10, 2007 | 11:10 AM
  #78
SCcobaltSS's Avatar
Hell yah warrenty that ****!
Old Aug 10, 2007 | 11:34 AM
  #79
SSdan's Avatar
Told you.
Old Aug 10, 2007 | 11:39 AM
  #80
R&C_rallySS's Avatar
The gauge should be under warnity. You may want to put the stage II pulley back on though haha
BTW, now that you know what it is. What do you think about the 2.9 pulley from Nate? If I were to get the same size gm stage II pulley but would be one of Nate's would the weight differance do anything? You would think if the blower could spin the pulley easier with a less weight pulley it would help out. I guess I'll wait until I get dual pass, and a H/E then get a 2.9 pulley and dyno tune.
Last edited by R&C_rallySS; Aug 10, 2007 at 11:39 AM. Reason: Automerged Doublepost
Old Aug 10, 2007 | 12:15 PM
  #81
SCcobaltSS's Avatar
I wouldnt worry about putting the 3" pulley back on. They should look at that for a boost gauge. I hope. If you want to be cautious about it do it. its easy. But when there is something wrong with my car engine or blower wise. I dont take my 2.8" off..
But glad you figured out what the problem was!
Old Aug 10, 2007 | 02:03 PM
  #82
Super_SS's Avatar
i didnt really figure it out...i decided to go run a gto that i lost to before i got the 2.9...and i beat it,so which means i did gain power and boost,but the gauge kept reading 10psi..and no way in hell a cobalt with 10psi will take a gto..and video will be posted up soon of that race...hahahaha
Old Aug 19, 2007 | 09:04 PM
  #83
Still waiting for that badass Vid haha +rep comming I'm sure! So you noticed a differance with the 2.9 then?
Old Aug 19, 2007 | 09:17 PM
  #84
KillerBee's Avatar
Originally Posted by Super_SS
can nate's bolts fit on the s2 pulley?i dont really want to use the gm bolts since i gotta trq them down...i just went to autozone and bought some ngk copper 1 step colder...gapped them to 0.040 and ill go see is there diffrence...if no diffrence ill just put the s2 back on and see what happens...
and on the back of nates pulley it says..2.9"
Yeah the bolts suppose to fit someone said they are a little smaller but Nates pulleys work inconjuction with gms stage 2 pully hub
Old Aug 20, 2007 | 04:23 AM
  #85
Super_SS's Avatar
i just went to the dealer to get my gauge replaced...didnt remove anything...went in there with all sorts of performance parts and on the receipt it still says COVERED UNDER WARRANTY...hahahaha,oh dam this is sweet...
and for ppl who wanted to knw,2.9 is super badass....im boost 17.5psi...time for coolin mods...and video of me beatin on the gto will be posted as soon as my idiot srt friend posts it up...he bizzi sleeping
Old Aug 20, 2007 | 01:54 PM
  #86
SCcobaltSS's Avatar
good to hear it was the gauge!
Psi Phreak
Feb 23, 2007 05:52 PM
Re4peR26
Jul 5, 2006 12:49 AM
