Need Answer ASAP - GMPP Cams
I am wondering if the GMPP cams in the link below will work on the Cobalt SS/SC?
http://www.crateenginedepot.com/stor...-P320C191.aspx
I did a search on them, but couldn't come up with a definate answer to this. Please, any knowledge on this is much appreciated and if it is a repost, my apologies.
They physically fit the 2.0L LSJ head, but the vacuum pump / cam sensor will not work in a stock engine.
specifically
specifically
The GM Performance Parts ECOtec cam set (88958648 set or 88958636/7 individually) is an aggressive race cam. They are not stock-replacement cams; they require upgraded valve springs and retainers. These cams were designed for a race motor, using the ‘06 L61 as the starting point. The cams will not fit the 2.4L LE5 head and will not work with the stock ECM or lifters. They physically fit the 2.0L LSJ head, but the vacuum pump / cam sensor will not work in a stock engine.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
