Need cooling mod
Need cooling mod
Wanna run a smaller pulley, already have the pulley. So I need like a heat exchanger.
Heard storys of some brands not fitting right.. so whats a affordable H/E that does fit correctly?
Pictures would be great! But Advice good too.
Thanks.
Thanks.
A 2.9 on the S2 tune is fine, along with an H/E will just help keep temps down and lower temps mean more power!
Will you feel a difference iunno.... it depends!
I did 70% distilled water, and 30% dexcool
I run the big cx racing HE, I had to trim the crash bar out and made my own brackets for it to fit. You cant tell from the outside. On the 2.9, my IAT2's are about 15-20* higher than IAT1's at WOT. On the 2.8, they are about 25* higher. It is not a bad job, search the how to section for a write up of how to plumb the HE in line with the stock unit. I think there is also a part list of what you will need in it as well.
[QUOTE=User Name:;4421856]I ran a 2.85 on an h/e alone. ran great but on the 42# injectors they started getting pissed off.
this is incorrect, lower temps just means safer reliable combustion. Lower IAT's does not make more power do research, just helps keep you from blowing up.
