Need h/e pump help quick!!
Old Mar 29, 2011 | 08:43 PM
klloyd's Avatar
My h/e pump is going out so i bought a new one from ZZP, installed it and it wont flow. I tapped on it and it makes a loud buzzing noise. So I took it back off and put the old one back on, now it wont flow either. I have no idea whats going on, i hook up the wire to the pump and it's barely blowing anything. Option b tank has fluid in it and the level is staying the same, any ideas?? I have the car apart now so quick advise would be helpfull. And yes I have the flow going the right way, tube pointing up is going back into the stock h/e lower tube is the inlet from the iption b.
Old Mar 29, 2011 | 09:14 PM
Joemaster70's Avatar
the loud buzzing means its working now u just gotta let it fill with coolant
i didnt have the Opt b kit on when i changed mine but i did however have the ottp h/e on and had to let it run a bit to get fluid in it
Last edited by Joemaster70; Mar 29, 2011 at 09:14 PM. Reason: Automerged Doublepost
Old Mar 29, 2011 | 09:52 PM
klloyd's Avatar
It finally bled out but I still have the old pump on. The new one was buzzing pretty loud, I don't hear the old one at all and never have. I'm going to call ZZP tomorrow and see if they will exchange it for me and I will put that one on whenever it gets here. I have to get another botle of water wetter before I change it out again anyway. When I put it all on with the option b originally it bled out realy quick. Whatever, it works for now and i'll sort out the new pump tomorrow. Thanks for the help though.
Old Mar 29, 2011 | 09:57 PM
the buzzing was the pump with no fluid in it, it's extremely loud when running dry. It's working fine just get some fluid in it
Old Mar 29, 2011 | 10:01 PM
klloyd's Avatar
Damn, ok I'll get some more fluids and swap it again and see if it works.
Old Mar 29, 2011 | 10:04 PM
remember to remove the cap off both ur Radiator resevior and Opt b kit it should run through once the pressure is released
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
