H
ey everyone im about to swapp my lsj to a saab intake mani and install charge piping with a block off plate for the bypass valve on the turbo, will also be adding a hks blow off valve.. i know many members have done this swapp before and im looking too see if some one can post some pics of there's.... something close up? maybe a few tips of were i should run the vacuum lines... also will be usung the zzp throttle body spacer inorder to keep my lsj throttle body. just looking for insight and to make this go smoothly
thank you in advance everyone!
I don't know what additional info you might need. It's a pretty straight forward install. Looks like it has gasket maker on it; I would definitely take a razor and clean all that off before installing it.
Vacuum hose connections just depends on how you have things routed. It looks like someone threaded in a brass fitting with a smaller OD on it - I put a fitting for my brake booster there, connected the boost gauge line right above that, top left is for my MBC/wastegate, and then the two on the bottom go to my AFPR and my BOV.
I skipped the LSJ TOB and opted for a LE5 TB. Neither one seems to fit without a spacer though, so that is slightly irritating.
