Turbo swap help
Old Jun 20, 2011 | 09:06 PM
burstss's Avatar
Turbo swap help
I it a zzp stage 3 kit from a friend it's a 2.4 turbo kit so to make it work on my 2.0 lsj what all do I need? Intake Mani? Alternator? Tensioner, anything else? Will the lsj throttlebody work?
Old Jun 21, 2011 | 07:48 AM
Frew's Avatar
What all did you kit from your friend come with?
Old Jun 21, 2011 | 02:29 PM
burstss's Avatar
its the entire stage 3 kit, oil lines, turbo ,charge pippes, fmic, dp, bov, wastegate, etc, but ill need my own intake manifold so
Old Jun 21, 2011 | 05:09 PM
Frew's Avatar
You can get an lk9 intake mani, sheet metal is the better choice but the lk9 can be picked up from saab directly for cheap, although you are going to have to machin the opening to accept the lsj throttle body, drill and retap the throttle body mounting holes, build a spacer for the map sensor etc, or you could pick up zzps alreadt modified lk9 mani, you will also need some sort of extension harness for the throttle box plug in I believe.
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
maliki778
Oct 1, 2015 07:39 PM
ThoR294
Sep 28, 2015 05:31 PM
