need some advice...
my mods are in my sig.
i just dont know what else i should do to the car. i mean i know whats out there i just need to know whats the next best bang for the buck. i just want performance mods...
i'm thinking
1. cat-less 2.5 down-pipe
2. header
3. tune
4. meth injection
5. dual end-plate
6. cobra h/e
7. ???
what order do you guys think i should put these mods in my car?
i'm thinking
2. header
3. tune
4. meth injection
5. dual end-plate
6. cobra h/e
7. ???
I got my CTI Header and DP from NewEraPerformance.com. Just specify whether or not you want a 3" DP or 2.5" DP. I opted for the 3" with a 2.5" neckdown at the end, that way if i ever want to get a 3" exhaust all i would have to do is whack off the 2.5" section and weld a #' flange on. The header and DP cost me $625 without a cat. You could probly get them to weld in an extra o2 bung if you plan on putting in a wideband o2 sensor. The exhaust I got from turbotechracing.com however i dont know who sells the corsa for the cheapst price, if you look and check the vendors im sure you can find it. Its a little expensive but I like it alot.
i would love too, trust me i want it... but i need supporting mods like exhaust, traction, and other ****...
does it bolt up to stock cat-back???
yah it will bolt up to the stock cat-back, it bolts right up to my corsa which is 2.5". The guy that i talked to i believe his name was Mike. All I told him was that i want a 3" collector with a 3" DP that had a 2.5" neckdown to bolt up to my corsa, stock exhaust, anything that 2.5", etc. Personally the header is more restrictive than the exhaust is, it has a 2" pinch right after the cat where the stock o2 sensor plugs in. Oh yah make sure you tell them that you want it catless.
yah he benefit from a tune but hes already got the stage 2 tune and is only running a 2.9" pulley, he's not really making that much heat to benefit from meth injection. if he was running a 2.7" pulley or smaller id say yah get it, maybe even a 2.8"pulley but its not really a necessity for him.
i'm thinking
2. header
3. tune
4. meth injection
5. dual end-plate
6. cobra h/e
7. ???
i'm thinking
2. header
3. tune
4. meth injection
5. dual end-plate
6. cobra h/e
7. ???
Header first
then DP
then a tune
then meth and dual end plate
then another tune
and no cobra H/E
hes gonna have meth and a dual pass end plate he doesnt need 3 cooling mods , if you want the heat exchanger then get it its only 100 but if you have meth and a dual pass i see no need
Hippo
Drag Racing
Sep 24, 2012 07:45 PM
dj4ever007
Mar 12, 2012 12:13 AM
