Need some help, exhaust backfire!
Old Oct 31, 2007 | 06:33 PM
Fingersmoran's Avatar
So heres the deal, I have 2006 ss/sc with stage 2, K&N cold air 2.85 pully and GMPP exhaust and manifold. Since the installation of the exhaust and manifold, when i am at full throttle, at 5800-5900 rpm my car starts to back fire and I loose power intermintantly. It does this to the 7000rpm redline.
Anyone have any ideas? Power from take off to 5800rpm is fantastic, its just when i hit high revs.
-shawn
Old Oct 31, 2007 | 06:35 PM
saunders1986's Avatar
well first thing, u shouldnt be running a 2.85 pully on a stage 2 tune, your at sea level........ u could run it if u were living in alberta or sask or somethin, but not van...... i thinking u have leaned out ur car to much, and its running lean.
Old Oct 31, 2007 | 06:37 PM
06blackg85ss's Avatar
sounds more like spark blowout... what plugs you got in there and what gap
Old Oct 31, 2007 | 06:39 PM
I dont think its the pully, it wasnt doing it with the stock exhaust. I have a bud with the same pully and he hasnt had this problem.
Old Oct 31, 2007 | 06:40 PM
ItalianJoe1's Avatar
Listen to the man, the answer lies in his question
Old Oct 31, 2007 | 06:41 PM
My plugs are NGK BKR7E's, gap im not to sure on.
Old Oct 31, 2007 | 06:43 PM
hmm if they are the copper ones... check the gap.(iridiums come pregapped and you can't change em).. should be @.035 if bigger, that could be your problem. also make sure they are all gapped the same.
Old Oct 31, 2007 | 06:45 PM
I think i gapped them at 4, i have another set, i will try 35, thanks.
Old Oct 31, 2007 | 07:00 PM
if theay are at .040 then that is more than likely you're problem
Old Oct 31, 2007 | 07:02 PM
I gapped my BKR7E's at .32 last time I changed them, and I haven't had any issues like that. I've run those plugs for a long time and they work great.
Old Oct 31, 2007 | 07:09 PM
.32 will work also... My friend (blackss05) was having that issue, checked the plugs and they were gapped at stock... regapped and the car is fine now
Old Oct 31, 2007 | 07:12 PM
Yeah, I want to pull mine soon and check, been running on the bottle for about 3 months now, just curious as to how the plugs are holding up.
http://www.magnecor.com/magnecor1/main.htm
^^ really good site for technical info on plugs and wires and such.
Old Oct 31, 2007 | 07:16 PM
**** man, on the spray you should be checking your plugs more often then that. With the old monte I used to check em after every hit... but I was also running a 400shot on the car lol
Old Oct 31, 2007 | 07:18 PM
Well, yeah, thats a small bit more than I run. I just use a 50 shot, and I use maybe 4-5 lbs a week at most, only a couple of sprays. Lately, I had a solenoid go bad and the weather has been shitty so I haven't used it at all in the last 2 weeks.
Old Nov 3, 2007 | 01:17 AM
THanks for the help, I gapped new plugs at .34, and it did the trick!
yey!
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
