New down pipe but problem
You NEED to use a tapered donut gasket as the surface of both flanges warp from the heat. A flat, thick gasket might work, 2 gaskets might work, 1 might work, putty/sealant will work for about 15 minutes. In the end, it's just a race against time.
Not for the 2-bolt downpipe to catback connection flange. Also, his downpipe is brand new. I highly doubt the flange warped.
Use a remflex for the dp-catback, because that will warp and leak over time. That section gets pretty hot.
