New Dyno #'s
New Dyno #'s
Engine mods are
GMPP Stage II
2.8" pulley
K&N Typhoon Cold Air Intake
LS4 Throttle body
Dual-pass Intercooler Endplate with Option B
ZZP Mid-length Header/3" downpipe with 2.5" Magnaflow Hi-flo cat
Stock cat-back with Magnaflow Hi-flo muffler
Wicked tuned (by WickedSS2005) to 11.6 AFR using an AEM UEGO Wideband
Before anyone starts flaming about a 2.8" pulley on the Stage II 42.5lb/hr injectors, during tuning, my IDC's never went above 95% and the pulse width stayed at or below 17.
Dyno pulls were done in 3rd gear at 94-95 degrees F and 33% humidity.
Whatcha think??
I think I definitely need a heat exchanger and meth...
GMPP Stage II
2.8" pulley
LS4 Throttle body
Whatcha think??
They are, but the big thing is the pulse width, which never went above 17. I will be getting the 60#'s here soon but these will be fine until then.
Engine mods are
GMPP Stage II
2.8" pulley
LS4 Throttle body
Whatcha think??
GMPP Stage II
2.8" pulley
LS4 Throttle body
Whatcha think??
http://www.youtube.com/watch?v=TI-JQl4xjRQ
i pulled a 258whp wit my 2.8 and 42# injectors with header d/p and 3" exhaust its on youtoube
well in any sense i will be upgrading to 60#'s here soon so it will be fine for a month or so until i get them in.
also i don't remember the pulse width being as high as 17 up at redline (7k) but idk i'll have to see if we saved that logging file
I agree. lots of good info there
so, i might be in the market for a meth kit and heat exchanger here now that i see the apparent heat soak.
i'm looking at the cxracing dual pass heat exchanger, the one listed here :
http://www.cxracing.com/mm5/merchant...gory_Code=HTEX
IMO it looks like one of the better ones made to fit the lsj's and on ebay it's only about $150
also in the market for a meth kit, and I am looking for opinions on different kits. any one who cares to chime in please do so
I've already got a tapped spacer plate (which btw works great with the ls4 throttle body) that is already tapped for meth / nitrous so i don't need to drill into the intake
Cptnslo
Sep 24, 2015 09:32 AM
