New LSJ Build in the UK
Old Jul 14, 2011 | 10:19 AM
  #101
Muncher's Avatar
But if you are changing the pistons even on a brand new engine you need to rebore it as all 4 pistons are not the same size even from standard.
Old Jul 14, 2011 | 11:00 AM
  #102
hawlyns711's Avatar
you may find my build page handy, I'm running a very similar setup to you minus the tvs.
http://www.ionforums.com/forums/perf...lding-lsj.html
enjoy and good luck
ps. lots of pics
Old Jul 14, 2011 | 12:47 PM
  #103
mrbelvedere's Avatar
thats not realy true considering the pistons now are cnc machined and not hand machined what needs to be done is the bore checked to make sure it is still within spec then check the piston to cylnder clearance
ill tell you the problem ive been runnnign into even on a low milage engines is shity finish machine work from gm on the bores
Old Jul 14, 2011 | 03:55 PM
  #104
Muncher's Avatar
There are actually 3 sizes of stock pistons, they select the size of piston which is the best fit for the bore and stamp the block to say which size should go in there.
Old Jul 14, 2011 | 04:48 PM
  #105
well i havent found any stampings on the blocks i have as of yet and if that is the case just have the bores miced and order custom piston diameter
Old Jul 17, 2011 | 04:34 PM
  #106
yup i found it but how do you decipher it
Old Aug 2, 2011 | 08:51 AM
  #107
Muncher's Avatar
I'm not sure, I was just told by someone who knew the build process well, that that was the way it's done.
When I asked whether I could swap the pistons straight over as it was a new engine and the bores should be all the same I was told I could not do it for this reason.
Old Aug 2, 2011 | 09:19 AM
  #108
well you can get the bores checked and get a custom oversize
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 28, 2015 12:51 PM
