New PCM, and car won't start
So we installed a ZZP S3 kit for a friend and the car is all done ready to go, but the security light won't go out on the dash after trying to start the car with the clutch down and leaving the key in the run position for over 15 mins.
Only thing we have not done so far is unhook the battery for more than 5 mins.
We turn the key on, clutch, try to start, leave the key on and the light stays on.....
Our friend drove to MI from CT to have this done, we need some help ASAP.
i have the same problem with my PCM . what is a security relearn? when i talked to big 3 racing ( a tuning shop in ohio ) they told me there was a " safety lock on it" and i needed to get that unlocked. anyone help me? i got my PCM from OTTP by the way. it is a stage 2 PCM
Now the car runs and drives great but it has 3 codes.
P0122
P0223
P0315
So, 2 throttle codes and 1 CPS code. Which is weird since we never touched the CPS. I'll go pop the battery and rest it later, and re check the TPS plug.
P0122
P0223
P0315
you get in the car with the doors shut, radio off, lights off, etc and turn the key to the ON position (dont start it tho)..then wait 15 minutes (make sure you wait that full 15) then turn key off and then try to start the car. turn key off then back to the position (again, dont start the car)...then repeat 3 times. If the security relearn is the problem, then it should start after that 3rd time!
Turbo Johnny
Feb 21, 2019 09:41 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
