new project doable?
Old Aug 12, 2008 | 09:38 PM
restonSS's Avatar
new project doable?
ok so i was just on OTT's website and i saw their Supertech 78lb valve spring kit. does that have everything i need to bump up my redline to say 7800 rpms? i mean the stock stage 3 from GM give you the option to rev to 8 grand so i am assuming with my mods i would still make power that high? would i even make power that high? or would i need to really do a cam swap as well to feel the benefits? i just wanna rev to 7800 or even 8000 just bc more revs are what tickles me i really need guys like area47 or someone who has done it but if you ahve any info that would be great. thanks!
Old Aug 12, 2008 | 09:40 PM
theneelster's Avatar
You need the neutral balance shafts as well...like 300 bucks. I think people would suggest you also go for a return style fuel upgrade as well but I don't know.
Old Aug 12, 2008 | 09:54 PM
restonSS's Avatar
where can i find neutral balance shafts? and cant i just re use the stock ones?
Old Aug 12, 2008 | 10:00 PM
BLAZIN07SS's Avatar
I'm too JDM for you
your not cammed so your not making power up that high anyway.
Old Aug 12, 2008 | 10:03 PM
restonSS's Avatar
well thats my point. lets say i get cams. i dunno if area has sold his 272 turbo cams but i could pick up those. back to the quesiton: cant i just reuse the stock neutral balance shafts?
Old Aug 12, 2008 | 10:06 PM
Smarty Art's Avatar
To safely rev to 8k you need neutral balancing shafts. The added stress from the rotation of the stock ones throws the engine out of balance.
Old Aug 12, 2008 | 10:08 PM
WhiteSSBalt's Avatar
Not a Sebring
restonSS, go here: https://www.cobaltss.net/forums/show...47#post2722447
and sorry, it has nothing to do with this thread, lol.
Old Aug 12, 2008 | 10:09 PM
restonSS's Avatar
^ it is saying the webpage cannot be found
Old Aug 12, 2008 | 10:10 PM
Not a Sebring
Whoops. Fixed
Old Aug 12, 2008 | 10:11 PM
restonSS's Avatar
ok well can someone direct me as to where i can find neutral balancing shafts for my car?
Not a Sebring
PM Rage NRG. He's a friend of mine........he had neutral balance shafts in his car at one point.
Plus supposedly these balance shafts free up like 10-15hp...that's what I read somewhere out there in the internet universe.
I'm not sure about the cams but I do know the gmpp ones they did make are hard as hell to find...probably jbp is your best bet. The project is doable but is going to be hella expensive.
You'd probably have more fun just swapping to the ls4 throttle body/spacer...good cheap mod.
Old Aug 12, 2008 | 10:13 PM
restonSS's Avatar
whitessbalt: i got to virginia tech. ill be there at the time of the meet and no offense, but im not going to drive 4+ hours just for a meet that may last 3 hours on top of having shitloads of work. im taking 8 classes which is a **** ton and the max amount of credits you can take. i dont have the time sorry.
theneelster: what the hell is that supposed to mean? swapping the throttle body? i dont get it? was that some kind of shot at me?
Old Aug 12, 2008 | 10:14 PM
Smarty Art's Avatar
You can get neutrals at Crate Engine Depot or AllEcotec.
Old Aug 12, 2008 | 10:15 PM
Um...no it was a recommendation. Costs about 125-175 depending on the condition of the t/b.
Old Aug 12, 2008 | 10:16 PM
Matt M's Avatar
Try Bates Engineering- http://www.batesengineering.info/
Old Aug 12, 2008 | 10:25 PM
bolus's Avatar
You can get the neutral balance shafts
http://www.crateenginedepot.com/stor...15-P336C0.aspx
Or you can just remove them which is less expensive. I have a friend that installed this himself in his garage.
http://levelzeromotorsports.com/stor...bdb28f232f9108
I went one step further and removed them completely and got a shorter chain to run the water pump
https://www.cobaltss.net/forums/show...=balance+shaft
I wanted to remove them to up the rev limit but also get rid of the extra weight. Those balance shafts are heavy
Old Aug 12, 2008 | 10:56 PM
restonSS's Avatar
theneelster: what does a ls4 have anything to do with this subject tho? like will it even give me a gain in power? it just seemed so off topic
bolus: what are the benefits (other than not having to buy another $500 balance shaft set) and what are the negatives that can come with having no balance shafts?
Old Aug 12, 2008 | 10:57 PM
Not a Sebring
Word. I just saw you had "Reston" as where you live. And Reston is like 20 min from me. But if your at school at Tech, I understand, lol.
Old Aug 12, 2008 | 11:00 PM
restonSS's Avatar
haha i wish we would have found this out at the beginning of summer. i def would have met up. sorry dude. maybe over winter break if not next summer haha!
Old Aug 12, 2008 | 11:02 PM
Not a Sebring
Gotcha.
Old Aug 12, 2008 | 11:12 PM
bolus's Avatar
Id break it down like this
balance shafts:
pro: reduce engine vibration
con: 10 hp to spin them,
Neutral balance shafts
Pro:higher reving, GM tested,
con: 10 hp to spin them, expensive, vibration, possible higher wear on the car / engine from vibration
balance shaft delete
Pro - 10hp gain, higher revving, 20? lbs weight savings
con - not tested a lot, requires more installation expertise, vibration, possible higher wear on the car / engine from vibration
I dont know if people notice the vibration much in their cobalts but I can certainly feel it in the Atom. The floor of my garage vibrates when the car is running. It feels like bass coming out of a stereo. In the car, its like a nice massage though
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
z28addiction
Sep 28, 2015 12:03 AM
Rduncanss06
Sep 27, 2015 11:17 PM
Bohb
Sep 27, 2015 09:11 PM
