Head removal
Head removal
Quick question,
I'm about to go remove the head on my friend's '05 SS, and I was wondering how easy it is to remove. Is it accessible without removing the rad? Can I get away with just draining the engine oil and coolant? Do I need to drain the intercooler aswell? Any help would be appreciated.. Thanks!
I would recommend draining oil and engine coolant. Aftercooler system can stay. You don't really need to pull out exhaust or intake manifolds. Just remove nuts/studs and they can sit in the engine bay. The head is very easy to remove on these. Nothing really needs to come out of engine bay.
Yea, I have done it that way too. It will just obviously make the head more heavy and ackward, but easily doable.
I put my pacesetter down through the top, so i dont see why that wouldnt work.
Just put something in the spark plug holes and make all 4 pistons flat across. You can just un-do the chain around the cam gears and don't need to worry about the cams spinning and valve/piston contact. The valve's won't reach that far down with all 4 pistons flat.
For head re-install, the front cover will obviously need to be removed for re-timing, but that is very easy as well.
Just get the GM 300HP build book, does a lot better than service manuals.
Well, I got as far as draining the coolant and oil, and removing the valve cover before I decided it was time for dinner. Will I need to get an inverse torx socket set for this?
The reason I'm taking off the head is from my overheating/compression thread. I'm just trying to determine if the headgasket is blown (99% sure it is), and check to make sure the head isn't cracked.
Make sure to have the head checked by a machine shop. Blown headgasket = warped head. Probably needs decked. Stock headbolts are stretch as well and will need replaced, recommend ARP or Golden Eagle stud kits.
agentirons
10-16-2015 02:11 AM
09-28-2015 12:51 PM
