nitrous?
Old Nov 13, 2008 | 11:08 PM
ssaddiction's Avatar
nitrous?
hey guys im looking into hookin up the ott nitrous kit. im just wondering if im going to have to have any supporting mods for it i want to run a 60 shot. will i need any other supporting mods? all my mods are in my signature and will i need to retune it?
Old Nov 13, 2008 | 11:16 PM
sick06cobalt's Avatar
to get the most out of it yes retune.. i would probably go with a HE or even meth.. but either way youll need something supporting you.
Old Nov 13, 2008 | 11:18 PM
Greased's Avatar
hmm... you might run out of fueling w/ the 2.9 and spray at the top end if your still on 42#
ask OTT though im sure they will help you
generally its meth or n20 not both.
HE isnt necessary
retune is.
^true i would get some 60s..
Old Nov 13, 2008 | 11:21 PM
idunn's Avatar
i wouldnt go anything over a 50 shot with stock pistons. just my opinion.
Old Nov 13, 2008 | 11:24 PM
yea i meant 50 but will it be ok the way it is with a 50 shot? with the mods i have?
Old Nov 13, 2008 | 11:30 PM
NVMYCOBALTSS's Avatar
It will be ok until it breaks the weakest point. You could get 10 passes or 100 bottles through it. As far as injectors go, as long as you are spraying a wet kit, bigger injectors are not necessary. The kit itself add's enough fuel for the kit as long as you pay attention to the jets you are putting in. The only support mod for a nitrous kit on these cars is a window switch for activation of the kit because cobalts are a "drive by wire" set up. Meaning there is not a throttle cable.
Old Nov 14, 2008 | 03:23 AM
Zach06CobaltSC's Avatar
There is nothing wrong with using methanol injection and nitrous. I run both and I recommend it. The Methanol Injection will help increase the octane which is much more safe when using nitrous.
Old Nov 14, 2008 | 01:27 PM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
HE isnt necessary
retune is.
Absolutely you can and should run a water meth system with nitrous. Why wouldn't you want the extra octane to ensure the motor doesn't run into spark knock. Nitrous is great for adding power. No doubt about that. But with is comes an rapid cylinder pressure increases as it dramatically accelerate the combustion process. This is why you start pulling timing more and more with increased shots of nitrous.
Think of a water methanol injection system as a massive octane enhancer. Which is simply slowing down and stabilizing the burn rate of the fuel.
Let me know if you have any other questions.
Rodney
Old Nov 14, 2008 | 01:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
copying me now huh? lol, you have any questions you can ask me at school or on here bro
06blackg85ss
83
Jan 18, 2017 04:35 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ncstateredline
Sep 10, 2015 07:22 AM
Brian MP5T
Nitrous Oxide
18
Nov 20, 2005 06:53 PM
